This is rather surreal. Somehow I converged on the exact same workflow outlined in this link, but only after hitting my head against the wall too many times to count. It is satisfying to know "I am doing it right." The only thing I would add that isn't mentioned is that the lossless intermediate method is faster under 2-pass encoding when the frameserve fps is slower than ffmpeg's fps of a lossless intermediate (i.e. bypass frameserving twice at the slower fps).
Simply a beautifully written workflow guide!
https://trac.ffmpeg.org/wiki/Encode/PremierePro
Indeed, if the filtering on its own takes the most time, especially compared to the encoding, then it may be faster to save the result of the filtering in an intermediate file and run the 2-pass encoding on this source instead of the slowly filtered frameserver script.
I believe MeGUI supports this method as well... -
FWIK, Vegas supports this as well.
Frameserving vs lossless export
By SameSelf in forum Video ConversionReplies: 17Last Post: 2nd Mar 2015, 21:47 -
Encoding Audio Files as Lossless PCM (.wav)
By Ronaldinho in forum Newbie / General discussionsReplies: 23Last Post: 7th Aug 2013, 07:45 -
Best lossless encoding video editor?
By mindstormer in forum EditingReplies: 5Last Post: 22nd Dec 2012, 06:09 -
drag & drop encoding to lossless?
By SignedupGuest in forum Video ConversionReplies: 9Last Post: 9th Sep 2012, 23:18
