I'm using MPC-HC x86 1.7.10.86 With LAV filters and ffdshow, the main issue is when i watch a 10 bit anime, the whole computer, even trying to press Ctrl+ALT+DEL, no response, then i have to restart my computer by power button, when i play 8 bit videos, it doesn't freeze up, so why is this happening? to be sure i tried disabling some background applications such as browsers and hardware monitoring, like MSI afterburner and ASUS ai suite. My system specs: AMD FX-8350 4.0 Ghz overclocked @ 4.8 Ghz stable with water cooling, GPU: EVGA GTX 760 2GB ACX, 32GB RAM DDR3, and Windows 10 Pro X64. I tried disable overall overclocking, with no luck, still freezes up. so any ideas what's causing this issue?![]()
Results 1 to 13 of 13
What happens with other players like Vlc Media Player(with built-in decoders)?
I don't have VLC, besides, I don't like it, because it doesn't use ffdshow filter to able to convert fps using SVP, other things, this the first time iv'e never encountered this problem, what i mean is that this has never happened before with MPC-HC, and it's really starting to annoy me. Everytime when I get a 10 bit video, then try to watch it, computer freezes up in seconds. So no, i don't want to use VLC because it's just so simple, not saying it's bad video player, it's just not for me!
Just try it and uninstall it after.
I've gotten into watching a few 4K videos, and they have crashed my computer just about every time I used LAV Filters. Obviously my 6 year old GPU can't handle them, so I've set LAV to not decode it and instead now my CPU does the decoding.
I already stress test it with Prime 95 for 6 hrs and nothing or anything malfunction, plus I have water cooling on my CPU! so it shouldn't be a problem, even though i recently tried the stock CPU clock, and still doing it so it's not the CPU, if it was the CPU, the whole computer would shut off for fail safe purposes, plus I added a 80 mm fan on the mosfets or VRM to stabilize CPU voltage flow, I tried not putting a fan on VRMs, the computer would just shut off, which is good, so it wont damage my motherboard's VRMs. So it's got to be a software related bug! as one of the user replied to me must be one of the LAV filters, which i need for the MKV without it, video won't play!
You don't need lav filters if you are just watching videos with mpc-hc,i have never installed them,i just install CoreAVC for encoding purposes.
Sure but it helps to offload the decoding onto the GPU instead of the CPU. I can watch 1080p HEVC videos on my computer with minor CPU demand because the GPU is handling most of it. Watch the same HEVC 1080p video in VLC, and my computer struggles.
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 10:22 -
watching nbc.com freezes
By madymo3d in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Aug 2014, 01:01 -
New computer FREEZES completely during render (Sony Vegas 11)
By ShaneJensen in forum ComputerReplies: 4Last Post: 20th Aug 2012, 10:12 -
Computer Locks Up, Freezes Completely After Being On About an Hour
By p_l in forum ComputerReplies: 33Last Post: 28th May 2012, 17:26 -
MPC wont play sound when watching DVD
By Anonymous1 in forum Software PlayingReplies: 1Last Post: 18th Oct 2011, 08:52
