More than a decade ago, I used a variet of graphics and capture cards to cap my analogue Sharp Viewcam (VL-E31) 8mm tapes for editing. The learning curve was huge and now, having used Vegas and DV tape cams since then, I am wondering if the original captures (now long deleted) were of the best quality possible. To that end, after quite a bit of research, I have a Cannopus ADVC110 with a view to redoing them while the tape and very old cam are still usable.
Key question, of course, is the best setting to use for the box, which converts the analogue into a DV capture which Vegas shows as:
720x576x24 at 25fps (I'm in the UK so us PAL)
32 Hz, 16bit stereo (even though the analogue signal is not stereo but I can convert this in Vegas by duplicating the single channel)
Beyond the tiny trip switches on the bottom of the box, there are no other settings on it to change. For info, my trip switches are:
1 format: PAL - on
2 NTSC set up level:
It's more common to select 48KHz sampling , rather than 32KHz. Most video formats use 48KHz.
I don;t think it matters which position the NTSC level switch is in. It sets the IRE level for NTSC signals, which have different values in different countries where the NTSC standard is used.
Doesn't apply to PAL
EDIT: New identical thread opened by OP here: https://forum.videohelp.com/threads/376541-Cannopus-ADVC110-best-settings-for-analogue-...m-cap-in-Vegas
Same answer given there... suggest you add to that thread....Last edited by pippas; 23rd Jan 2016 at 09:25.
Footage looks fine as MKV and AVS, but glitches in Vegas
By badmojorayman in forum EditingReplies: 2Last Post: 16th May 2014, 09:35 -
Help with export settings for AVCHD source footage
By celtics23 in forum Video ConversionReplies: 3Last Post: 7th Jul 2013, 17:05 -
Vegas 6 & Vegas Studio 11 - Identical Settings, Different Quality Renders
By Hegelian in forum EditingReplies: 2Last Post: 1st Aug 2012, 03:06 -
Best settings and format for ARCHIVE footage ?
By Bansaw in forum Video ConversionReplies: 11Last Post: 28th Apr 2012, 09:55 -
Correct Project and Sequence Settings for footage from Panasonic TM300?
By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 12:34
