  1. hi
    my pot player not play next file manual not whit keyboard key and mouse i changed "General File open method: open selected file" but pot player play next file automatically and i don't want play automatically
    and my next question is how can i change next file play method from right click of mouse to left click ?
    I guess you have tried change keyboard and mouse command under Preferences and General->Mouse and Keyboard? And clicked Apply? Still no change?
    Tried latest PotPlayer? Or maybe an older version. https://www.videohelp.com/software/PotPlayer/old-versions#download
    Or last ask in https://potplayer.daum.net/forum/
  3. my first problem is solving but
    in my pot player if i want to play next i have to use right click in my mouse i cant find any option in mouse Preference to change right click to left click for use next file play .
  4. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Does this not work for you? I have 1.6.56815 version but should not be that far out of date.
Name:	ScreenHunter_182 Dec. 29 12.23.jpg
  5. thank but i mean this two Button in picture Click image for larger version
    this two Button works right click of mouse for next our previous file play but i want to changed to left click
  6. Originally Posted by hossein4276 View Post
    thank but i mean this two Button in picture Image
    [Attachment 35020 - Click to enlarge]
    I think that the feature you're looking for is implemented on the level of skin customisation. So the solution is to find a skin which has it or a skin with 4 buttons and not 2 (with double functions like in Default skin). For example here: http://daumpotplayer.com/category/skins/ or just ask google: PotPlayer+skins. If you prefer specifically Default one you might need to dig deeper - maybe somebody "remixed" it the way you like it.
  7. Member Budman1's Avatar
    Jul 2012
    Okay this may be tricky. My Skin, as AllisOne points out, works as you wish but this skin was no longer selectable if you delete the old Potplayer before installing new or just install latest for the first time. I had to install an old version and then install the later one over top of the old.. This allows the old skins to remain.
    The picture below shows left click = Next, right click = 30 advance.
    Name:  ScreenHunter_182 Dec. 29 22.18.jpg
    And this is the skin I prefer for these reasons.
Name:	ScreenHunter_182 Dec. 29 22.19.jpg
