Results 1 to 12 of 12
    May 2015
    Cleveland, Ohio U.S.A.
    I have 77 mp2 files that need to be batch decompressed. I tried with BeSweet GUI but it only does mp3 batch. I tried doing a few via it's registry entry under the software name Danni, it's too annoying that way. Couldn't use audition or EAC because they can't read them.
    Anyone know how to make this easier?.
    The free and simple Xmedia recode can convert your audio files to anything. Load your mp2 files, choose custom profile and format: wav, mp3, aac, etc.
    And you can't decompress a compressed audio or video. You are reconverting and losing quality for every conversion.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Try WinFF.....it has audio only settings but not sure about batch.
    May 2015
    I have to because I want to tag them but these mp2/mpa files can't be tagged. That's why I'm re-encoding.
  5. Go for ffmpeg - bellow PCM WAV examples
    24 bit
    @ffmpeg -threads %NUMBER_OF_PROCESSORS%*1.5 -i %1 -vn -c:a pcm_s24le -af "aresample=resampler=soxr:dither_method=3" -y %1_24.wav
    16 bit
    @ffmpeg -threads %NUMBER_OF_PROCESSORS%*1.5 -i %1 -vn -c:a pcm_s16le -af "aresample=resampler=soxr:dither_method=3" -y %1_16.wav
    https://forum.videohelp.com/threads/356314-How-to-batch-convert-multiplex-any-files-with-ffmpeg
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Oh yea....that's MUCH easier than something like WinFF where you can actually SEE what you are doing.
  7. DECEASED
    Jun 2009
    Heaven
    You can wrap MP2 streams in the MP4 container and then tag the new MP4 files.
    Whereas lossy recompression always means some loss of quality.
    BTW, MP3s were not designed to be tagged either — the ID3 tags are just an ugly hack.
  8. Originally Posted by hech54 View Post
    not sure what kind of functions are exposed in WinFF - from my perspective ffmpeg without GUI FE works OK.
  9. Banned
    Oct 2014
    Northern California
    You can't find a taggable container that allows mp2?
    Oops, El Heggunte beat me to it.
  10. Member bat999's Avatar
    Feb 2008
    ... but these mp2/mpa files can't be tagged...
    If you say so.
    May 2015
    Found a easy way with an old japanese program called SCMPX. Decodes in batch but all mp3 encodes have bad last frame like WMP 11 mp3 encodes.
    Used EncSpot Pro to look for bad frames.
    May 2015
    If you say so.
    They had the wrong ext. to begin with, mp3 rather than mp2 according to GSpot codec info.
    I don't use Lame APE tags, just ID3 v 1.1 via the file properties summary.
