Results 1 to 14 of 14
    May 2015
    united states
    I have a AVR Video file that I can not get to play on anything. I also can not convert it into a different format. I HAVE to be able to get the video to open. I have been working on it for weeks with no luck. Please help!
    Thank you
  2. Is this from a set-top box? What have you tried to open (play) it in? What software have you tried so far?
    May 2015
    united states
    it is from a parking lot surveillance camera . I can't name one software that I haven't tried. Nothing works. Frustrating!! Supposedly I need a old macintosh OSX similar to MPEG2. I even installed windows 9 media player. It tries to play but its not good enough.
  4. Surveillance camera manufacturers use their own custom players sometimes and files can even be encrypted.
    Do you know the manufacturer of the surveillance system? The files are most likely MPEG-TS files.
    If they are encrypted they won't play in anything. Try using MediaInfo to see what the files contain.
    You can post a text only version of the results here for others to look at.
    May 2015
    united states
    no I do not know the manufacturer. But here is the text from mediainfo
    General
    Complete name : D:\02082013-0130AM_02082013-0300AM.avr
    Format : AVC
    File size : 1.86 GiB
    Video
    Format : AVC
    Format profile : Baseline@L2.1
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=12
    Width : 704 pixels
    Height : 240 pixels
    Display aspect ratio : 2.933
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
  6. I'm a Super Moderator johns0's Avatar
    canada
    Try playing the file with mpc-hc,it should be able to decode it.
    May 2015
    united states
    Nope it didnt work. It says can not render file
  8. I'm a Super Moderator johns0's Avatar
    canada
    Can the original camera system play it?
    Feb 2004
    Australia
    Try this from everfocus
    List of applications here
  10. Anybody come up with a solution for this? I can't seem to get a security video I have that's .avr to play with any player either. The text from Mediainfo reads:
    General
    Complete name: C:\05022016-0113AM_05022016-0130AM.avr
    Format : AVC
    File size: 266 MiB
    Video
    Format : AVC
    Format/Info: Advanced Video Codec
    Format profile: Baseline@L3
    Format settings, CABAC: No
    Format settings, ReFrames: 2 frames
    Format settings, GOP: M=1, N=12
    Width: 704 pixels
    Height: 480 pixels
    Display aspect ratio: 3:2
    Color space: YUV
    Chroma subsampling: 4:2:0
    Bit depth: 8 bits
    Scan type: Progressive
    None of the solutions I've read about seem to work. Any info would be much appreciated.
  11. That looks like a raw h.264 video. Rename it .h264 instead of .avr. Then you can use a muxer to mux it into a MP4 or MKV file.
  12. Thanks, jagabo!! That seemed to do the trick!
  13. VLC can play raw .h264 files too.
