Hi guys,
I have no experience with video as such and English is not my first language, so please bear with me. I am filming sports games with a camcorder (can not remember the brand) and the settings on the camera is preset to prevent the multiple users from messing things up for the next one who use it. The files come in .mts format.
I have always converted to .wmv and have been happy with it, but now I need to convert to .mp4 since some features in the program I use for analysis are not available unless I use .mp4.
My problem is the following. I have used a preset recommended by the analysis program in GOM video converter, but I still feel that the output is far from the quality I get from the original .mts files or the files I usually convert to .wmv. It runs smoother most of all, but also I feel that the general quality is better. The output file was around 1,3 gb and since I am looking for the best quality and not really caring about the size of the output file I looked at the preset and tried to improve quality. I cranked up bitrate from 2 to the maximum of 10 and I checked boxes under “Video effects” such as, deblock more, smoothen more and sharpen more. The output file was no nearly 4 gb and I expected great things. Here is the thing. I can not see the difference between the two .mp4 files I have created (with the original preset and my own) if my life depended on it. Maybe the one I created runs a bit smoother, but it is still far from the quality from the original .mts (despite it being substantially more space consuming).
What can I do to improve quality, or is .mp4 just “worse”? Please help me!
Results 1 to 30 of 42
I would start with vidcoder. Use the high profile preset. Under Settings->Video can you adjust the constant quality setting, lower it for better quality but bigger file size.
okey: Try remux first. See Cornucopias reply. I thought you wanted to shrink it first.Last edited by Baldrick; 15th Feb 2015 at 12:29.
You should not be "converting" at all, if possible. Ever. Most peoples' and apps' interpretation of "conversion" is to re-encode. But you don't necessarily need to re-encode.
MTS is a container (Mpeg Transport Stream).
MP4 is a container (Mpeg 4 File format).
Your upping of the bitrate, noise reducion, etc. is barely offsetting the loss you are incurring from re-encoding. But for those containers (and their most common contents: AVC video streams and AC3 or AAC or MP2 audio streams), ALL you need to do is "change the container". This is known as "re-multiplexing" or re-muxing. A number of apps can remux from MTS to MP4. Doing so will maintain the originals' quality.
Me, I'd probably use ffmpeg. Here is a batch script that converts all mts files in a directory to mp4:
ScottCode:for %%a in ("*.mts") do ffmpeg -i "%%a" -vcodec copy -acodec copy "%%~na.mp4" pause
...This of course assumes that you are not needing to do any modification of the content... -
Thank you very much for your help.
Which one do I need to download?
32-bit Downloads
64-bit Downloads
Download FFmpeg git-2a72b16 32-bit Static
Previous FFmpeg 32-bit Static Versions
Download FFmpeg git-2a72b16 64-bit Static
Previous FFmpeg 64-bit Static Versions
Download FFmpeg git-2a72b16 32-bit Shared
Previous FFmpeg 32-bit Shared Versions
Download FFmpeg git-2a72b16 64-bit Shared
Previous FFmpeg 64-bit Shared Versions
Download FFmpeg git-2a72b16 32-bit Dev
Previous FFmpeg 32-bit Dev Versions
Download FFmpeg git-2a72b16 64-bit Dev
Previous FFmpeg 64-bit Dev Versions
And can the program merge files or do I have to do that through another program? -
Use the 32bit static version.
And you can read https://forum.videohelp.com/threads/356314-How-to-batch-convert-multiplex-any-files-with-ffmpeg how to run the batch command. Use Cornucopias batch code. -
Note that certain stream codecs may not be acceptable in all containers. For example, the LPCM audio stream cannot be muxed into the MP4 container by most muxers, so if you have one of those stream types, you need to try other options.
If in doubt, use MediaInfo to tell you what the contents are.
Scott -
I used the program and it seemed to work!
But the quality is not exactly the same. The image matches the quality of the original, but the smoothness is not nearly as good. It almost seems laggy. Watching the files back to back makes this very obvious. Any idea why this is?
Also it did not merge the original files. What do you recomend for doing that without "converting" it?Last edited by Miti; 15th Feb 2015 at 13:55.
Your playback could be choppy because you probably copied AC-3 audio, which is not expected in an MP4 container (they usually use AAC). By "merge," do you mean combine files in sequence into one big file? If so, you can do it with FFmpeg's concat demuxer.
Ok thank you. So how can I do it with the right audio?
Yes that is exactly what I mean. -
I think .mts is better that .mp4
Hope this help.
https://www.youtube.com/watch?v=u0J-ANZlyqM
https://www.youtube.com/watch?v=ukyTLOybi3I -
Post the full details from your mts. Open in mediainfo, view->text. Or mediainfoxp.
General
Complete name : D:\OB kampe\FFMPEG\Test\00139.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 1.98 GiB
Duration : 53mn 15s
Overall bit rate : 5 319 Kbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=13
Codec ID : 27
Duration : 53mn 15s
Bit rate mode : Variable
Bit rate : 4 842 Kbps
Maximum bit rate : 16.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.125
Stream size : 1.80 GiB (91%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Duration : 53mn 15s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 97.5 MiB (5%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 53mn 15s
I hope this is the info?Last edited by Miti; 15th Feb 2015 at 15:26.
How are you watching it? What software? The smoothness is probably from your program automatically deinterlacing the transport stream, but not the MP4. Set it to "bob" deinterlace or "yadif 2x"
I am watching it in Media Player. The thing is I am making individual clips from the file to each athlete. It has to be "watchable" without to much hassle for them.
Are the athletes going to know what interlace is ? I'm going to avoid stereotyping
but I'm going to say probably not
25 frames per second interlaced is 50 fields per second. That's 50 moments in time per second represented. Each field is like a 1/2 sized frame. If you single rate deinterlace, you only see 25 moments in time per second. Only 1/2 the data is retained. The motion is choppy, not good for sports. If you double rate deinterlace, you see 50 moments in time per second. Much better
WMP will double rate deinterlace interlaced transport streams automatically , but usually won't do it for other formats (except DV-AVI)
If your requirement is MP4 container, you should probably deinterlace it. Many programs won't know to deinterlace it. But if you re-encode with a lossy format, you're going to lose quailty . The "best" option is to keep it interlaced and re-wrap it as MP4, and just activate the deinterlacer during playback. No quality loss, and the re-wrapping will be many times faster than re-encoding it. You watch with deinterlacer activated in other programs like VLC. Perhaps you can give instructions to the ahtletes. But what sports analysis program are you using? Can it handle interlaced MP4 ? -
Then leave them as .mts
You can trim losslessly with ffmpeg by cutting on I-frames and use stream copy. Save as .ts
*Edit* If the players are going to watch the clips on their tablets, laptops or phones, then you might as well deintelace and save as mp4. Use Vidcoder, it's easy to use, just make sure to encode audio as aac.Last edited by racer-x; 15th Feb 2015 at 16:30.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
They will NOT know what interlace is for sure.....and I do not know either
I need it to be MP4 in order for it to work, but whether or not it can handle interlaced MP4 I can not know for sure before trying. I am using Sideline Video Analyzer through XPS Network.
I have an option to deinterlace in GOM - would you recommend that I try it? Right now the problem seems to be that the testing done with GOM gives lower quality in picture, but is smooth and the testing done with ffmpeg gives a good quality picture, but is laggy. -
Try it out
Well you can modify cornucopia's ffmpeg commandline to batch deinterlace and re-encode. It will be much much slower to process than "stream copying" the files, but end result should play smoother in all players if your device/computer can handle it
I used -crf 16 in this example. Lower values give higher quality / larger filesizes; you can adjust it later until you are happy with the quality. Yadif is used to double rate deinterlace . It's resized to 1920x1080 "square pixels". Try it out on a few short clips first.
Code:for %%a in ("*.mts") do ffmpeg -i "%%a" -vf yadif=mode=1:parity=tff -vcodec libx264 -s 1920x1080 -crf 16 -acodec copy "%%~na.mp4" pause -
Thank you very much. But I am a total newbie and the clips I have are all relatively large. I do not really care about the size of the outputfile (as long as it is under 10 gb), but more concerned with quality and ability to watch it on different devices without changing settings. Would "-crf 1" then theoretically give me the same quality mp4 as the original mts? -
-crf 1 will be several times larger than the original . -crf 0 is lossless compression, but it won't be able to be played by some devices. You probably can't see the difference even around crf 10, unless you go frame by frame and zoom in
If you need device compatibility, you may need to specify some other target settings. The reason is not all devices are "strong enough" to decode all types of compression and settings. Which typical devices will this be played on ? -
If compatibility across multiple devices is a concern, I would go with this script instead:
Code:SET PATH="C:\FFMpeg" for %%a in ("*.mts") do ffmpeg -i "%%a" -vf yadif=mode=1:parity=tff -s 1280x720 -c:v libx264 -level 41 -pix_fmt yuv420p -preset medium -crf 19 -c:a aac -strict experimental -ar 48000 -ab 256k -f mp4 "%%~na.mp4" pauseGot my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
One problem is some devices cannot handle high bitrates , certain encoding settings . Using a low crf value will result in high bitrates. You usually have to cap the bitrate with --vbv-bufsize and --vbv-maxrate. The settings differ between different target devices
Some GUI's have presets for various devices e.g. handbrake/vidcoder , xmediarecode etc... It's impossible to give specific advice for such a vague scenario -
How long would you expect it to take to run files through this? I am trying it out now and there is a something in the .bat file called "time". If this refers to the point in the video it is currently working at, it takes a very long time (so far 45 min and 4 minutes out of 78). I do not know if the "time" slot in the .bat file is connected to the time in the video or not. -
The time is the running time duration in a single video of the batch. (e.g. if it's a 60min video, and it says 45min, then you are 3/4 done of that single video)
It was mentioned re-encoding would take much longer than re-wrapping. Not only do you incur quality loss, but much slower when you re-encode with a lossy format.
The speed depends on your computer specifics. Faster computer will convert it faster. If it's too slow for you, you can use a faster encoding preset e.g. -preset:v veryfast . The quality is slightly reduced and compression will be lower. Currently it's at "medium" which is the default. There are slower presets as well
There are "better", higher quality , slower deinterlacers in avisynth you could use too. But there is a bit of a learning curve -
Impossible to say
The only thing you can say for certain, is lower CRF values will yield larger filesizes
When you use crf encoding, it's 1 pass "quality" based, and the bitrate will depend on content complexity
Usually, if you have complex content (difficult to compress), eg. lots of motion, lots of noise, filesizes will be larger
