http://www.hotstar.com/
When i register this site i faced Country restriction then i bought VPN and solved that problem. But problem is i couldn't download anything. I can't stream HD videos because of my poor net so i want to download and keep those epo.
I tryied so may ways nothing is working. Even i try with this video but its not working.
https://www.youtube.com/watch?v=s8SPfb2qCzw&list=WL&index=11
I need this movie badly. I would be very grateful if you would help me out.
http://www.hotstar.com/#!/watch-nanban-online-1000036211-m
Thanks in advance.
Results 1 to 20 of 20
Hi YaMiN ,
I could give you an address , but it'll be wrong due to the ip is mine and not yours .
My suggess do the process below .
Code:=== Under Firefox write about:addons <return> Do a search for DownloadHelper <return> Select "DownloadHelper 4.9.24" and install it === or === http://www.downloadhelper.net/ http://www.downloadhelper.net/install.php http://www.downloadhelper.net/manual.php ===
Cheers .JE SUIS CHARLIE !!! -
Hello aazerty,
I tried with DownloadHelper 4.9.24, its not working bro. r you able to download?
If there is way to download not matter how difficult that is. please just provide that information here.
Thanks in Advance. -
Hi YaMiN ,
Code:Nothing watchable with http://www.hotstar.com/#!/watch-nanban-online-1000036211-m Try : https://www.youtube.com/results?search_query=nanban+comedy+2012 and find what you need .
hello aazerty,
Hahahaha that's not i want, i want to download everything from there. Not just this movie. will you tell me those way brother? -
Hey man ,
You said :
> I need this movie badly .
THIS means one !!!
Other wise you should have said : THESE MOVIES !!!
Do it by yourself . I have not time to spend with this search .
@aazerty, Thanks bro for your time.
Is there anybody will here will help me on this. -
Its just through Adownloader its not possible there must be other way. Even i get slow download speed from that which is really annoying. Last night i tried to download one TV episode which is run-time : 2 hour.
After downloading through Adownloader that is 1 hour 20 mins, which take me whole night to download. So, i hope somebody please help us to download from there. -
Check my last post at:
https://forum.videohelp.com/threads/369954-First-Desktop-Folder-Opens-Slowly -
Hello YaMiN, nice to see you again.
I'm sorry, I have not enough time to properly examine all that but you said that you can play the video (or any videos you want on that site)? so you could use Internet Download Manager for example (moreover, in your youtube video, the guy uses IDM!), sometimes it can download more things unlike others softwares like DownloadHelper.
If it's not working, you need softwares a little stronger and to download it with the source code (again, in the video from youtube, the guy uses this technique) so there should be considered to use a rtmp downloader's software.
Good luck for the rest, pal. -
Hello WazaKrash bro,
Brother, For last 2 month i m with this, i run over all forum nobody is helping and there are tons of user like me who cant download from there or for poor net connection then can't watch,so they want to download and watch those TV/Movies. I tried with all those software's that u named, none is working. Feeling hopeless, u know anybody who can crack this (I will paid for that) Or any type of help appropriate able.
Thanks for kind replay brother. -
maybe like this
https://forum.videohelp.com/threads/369812-How-to-Rip-From-Daisuki-net?p=2370928&viewfu...=1#post2370928
i can't try because i don't find a good vpn that work -
I know for a fact, that blocking VPN's are the new thing this days.
Try your VPN on a Non-Supported browser.
Tools > Proxy > Customize...
something like that.Last edited by DJ_ValBec; 11th Feb 2015 at 20:05.
@ biezom
Use vpn from ibvpn.com, they ofter free 6 hour trial, install their software, enter your login info, select india and click connect. Then u can see easily. Now will you plz try for me and if it work plz let me know.
@DJ_ValBec :
Through ibvpn.com i see Hotstar all feature but i can't download. Plz help. Thanks. -
ok, dude. I understand you, me too I have some videos that I can't download...
if you say that conventional softwares doesn't work then you have to go to the next level, that is to say with tubedigger, rtmpdump or ffmpeg.
It's really strange, with a vpn I can't see the movie too... but it's looks like the method with IDM of the youtube video really works yet.Last edited by WazaKrash; 13th Feb 2015 at 06:20.
I wanted to say that too, if you can play the video then you can find a m3u8 link.
A nice forum's member explains the method very well :
he explained that here : https://forum.videohelp.com/threads/370002-Can-Full-Episodes-From-Network-Websites-%28e...Recorded-on-PC
