Results 1 to 9 of 9
    Dec 2014
    South Africa
    I am using a microphone on both XLR inputs on a Canon XF100 When converting MXF files to AVI in order to do editing, there is sound only on one channel when playing back the AVI file. However when playing back the MXF file on the Canon XF Utility, there is sound on both channels. I have tried 3 different MXF converters and I get the same result. Operating system is Win7 64 bit.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Wow....two posts and you've broken the forum rules already.
    GREAT job.
    https://forum.videohelp.com/threads/369110-Audio-Problem-with-MXF-File-Conversion
  3. Your conversion software is probably looking only at the 1st mono track
    You would need to mix dual mono tracks to a single L+R stereo if you wanted a single audio track
    What kind of "AVI" are you using? ( what compression ? )
    Why don't you edit the MXF natively ? What editing software are you using ? Most "pro" level NLE's will be able to edit these natively and access the audio as is
  4. And whatever software you are using, be sure to ingest the entire folder structure of the canon footage -- not just the individual .mxf files.
    Dec 2014
    South Africa
    I am using Pinnacle Studio and it can not open MXF files. The Audio settings on the converter is: AC3 2channels stereo, Sample rate 48000kHz & bitrate is 224.
    I need 2 separate channels, one each for each XLR input
    Dec 2014
    South Africa
    GREAT job.
    I do apologise.
  7. Originally Posted by Carl Enslin View Post
    2 separate channels, 1 audio track ? or 2 separate audio tracks, mono ? Pinnacle probably can't handle the 2nd option
    I would advice to keep uncompresseed audio, instead of AC3 (you incur unnecessary quality loss)
    Cornucopia mentioned this in your other thread, but ffmpeg or ffmbc can be used to batch process your video files (batch mix dual mono to stereo). I've done this with a mixed XF100/XF305 project
    Answer the previous question about "AVI" - what kind of AVI ? What video compression ?
    Another option might be to rewrap into a transport stream (MTS, M2TS, TS) - Pinnacle should able to handle that
  8. Also post the mediainfo report of your files . view=>text , copy & paste the results back here
    Dec 2014
    South Africa
    Thanks for your help so far. this is the converted video info
    Format : AVI
    File size : 144 MiB
    Duration : 1mn 38s
    Overall bit rate : 12.3 Mbps
    Writing application : Lavf54.59.106
    Video
    Format : AVC
    Format profile : Baseline@L4.1
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : H264
    Duration : 1mn 38s
    Bit rate : 12.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.309
    Time code of first frame : 00:55:44:04
    Time code source : ISMP
    Stream size : 141 MiB (98%)
    Writing library : x264 core 135
    Encoding settings : cabac=0 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=4 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=20 / rc=abr / mbtree=1 / bitrate=12000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1mn 38s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 2.25 MiB (2%)
    Alignment : Aligned on interleaves
    Interleave, duration : 24 ms (0.60 video frame)
    Interleave, preload duration : 24 ms
    Writing library : LAME3.98ÈL° Ê&d†
    This is the MXF file info:
    Format : MXF
    Commercial name : HDV 1080i
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 315 MiB
    Duration : 1mn 38s
    Overall bit rate : 26.8 Mbps
    Encoded date : 2014-12-24 14:50:26.000
    Writing application : CANON XF100 1.00
    Writing library : CANON XF100 1.00
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Format settings, picture structure : Frame
    Format settings, wrapping mode : Frame
    Codec ID : 0D01030102046001-0401020201050300
    Duration : 1mn 38s
    Bit rate : 25.0 Mbps
    Standard : Component
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.643
    Stream size : 293 MiB (93%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format settings, wrapping mode : Frame (AES)
    Codec ID : 0D01030102060300
    Duration : 1mn 38s
    Bit rate : 768 Kbps
    Channel(s) : 1 channel
    Bit depth : 16 bits
    Stream size : 9.01 MiB (3%)
    Audio #2
    Format : PCM
    Duration : 1mn 38s
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Time code settings : Material Package
    Time code, striped : Yes
    Other #2
    Type : Time code
    Format : MXF TC
    Time code settings : Source Package
    Other #3
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    I do not know how to do/find/calculate the compression. It is HD AVI.
    Thank you kindly,
