Hello,
i am trying to cut a video with ffmpeg while keeping the same format and without reencoding the video.
The problem is that the format of the output is not the same.
The audio bitrate is less, the video bitrate is slightly changed and also the clip info has changed (this is only metadata right ?)
Also, the input file was a MP4, can ffmpeg keep the same format with all video formats ? Such as AVI, WMV, MOV, DIVX etc. ?
Thank you !
Command Line Arguments
Mplayer Identify OutputCode:ffmpeg.exe -y -i "C:\Movies\304640436.mp4" -ss 00:00:06.5 -t 8.40 "C:\Movies\304640436.clipped.mp4"
Original
ClippedCode:MPlayer2 git-6ce3c2a (C) 2000-2013 MPlayer2 Team Custom build by Redxii, http://smplayer.sourceforge.net Compiled against Libav version v9-553-g311443f Build date: Fri Feb 22 16:43:48 EST 2013 Playing c:\movies\304640436.mp4. Detected file format: QuickTime / MOV (libavformat) ID_VIDEO_ID=0 [lavf] stream 0: video (h264), -vid 0 ID_AUDIO_ID=0 ID_AID_0_LANG=und [lavf] stream 1: audio (aac), -aid 0, -alang und [ass] No usable fontconfig configuration file found, using fallback. Clip info: major_brand: mp42 ID_CLIP_INFO_NAME0=major_brand ID_CLIP_INFO_VALUE0=mp42 minor_version: 0 ID_CLIP_INFO_NAME1=minor_version ID_CLIP_INFO_VALUE1=0 compatible_brands: mp42mp41isomavc1 ID_CLIP_INFO_NAME2=compatible_brands ID_CLIP_INFO_VALUE2=mp42mp41isomavc1 creation_time: 2014-11-06 00:14:31 ID_CLIP_INFO_NAME3=creation_time ID_CLIP_INFO_VALUE3=2014-11-06 00:14:31 ID_CLIP_INFO_N=4 Load subtitles in c:\movies\ ID_FILENAME=c:\movies\304640436.mp4 ID_DEMUXER=lavfpref ID_VIDEO_FORMAT=H264 ID_VIDEO_BITRATE=4441456 ID_VIDEO_WIDTH=1920 ID_VIDEO_HEIGHT=1080 ID_VIDEO_FPS=25.000 ID_VIDEO_ASPECT=1.7778 ID_AUDIO_FORMAT=MP4A ID_AUDIO_BITRATE=256000 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 ID_START_TIME=0.00 ID_LENGTH=170.04 ID_SEEKABLE=1 ID_CHAPTERS=0 <vo_directx><ERROR>Your card doesn't support overlay Opening video filter: [scale] [ass] auto-open Selected video codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [libavcodec] ID_VIDEO_CODEC=ffh264 Selected audio codec: AAC (Advanced Audio Coding) [libavcodec] AUDIO: 48000 Hz, 2 ch, floatle, 256.0 kbit/8.33% (ratio: 32000->384000) ID_AUDIO_BITRATE=256000 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample) ID_AUDIO_CODEC=ffaac Starting playback... VIDEO: 1920x1080 25.000 fps 4441.5 kbps (555.2 kB/s) ID_VIDEO_ASPECT=1.7778 [swscaler @ 02205d80]using unscaled yuv420p -> bgra special converter VO: [directx] 1920x1080 => 1920x1080 BGRA No bind found for key '0x1b '. Exiting... (Quit) ID_EXIT=QUIT
Code:MPlayer2 git-6ce3c2a (C) 2000-2013 MPlayer2 Team Custom build by Redxii, http://smplayer.sourceforge.net Compiled against Libav version v9-553-g311443f Build date: Fri Feb 22 16:43:48 EST 2013 Playing c:\movies\304640436.clipped.mp4. Detected file format: QuickTime / MOV (libavformat) ID_VIDEO_ID=0 [lavf] stream 0: video (h264), -vid 0 ID_AUDIO_ID=0 ID_AID_0_LANG=und [lavf] stream 1: audio (aac), -aid 0, -alang und [ass] No usable fontconfig configuration file found, using fallback. Clip info: major_brand: isom ID_CLIP_INFO_NAME0=major_brand ID_CLIP_INFO_VALUE0=isom minor_version: 512 ID_CLIP_INFO_NAME1=minor_version ID_CLIP_INFO_VALUE1=512 compatible_brands: isomiso2avc1mp41 ID_CLIP_INFO_NAME2=compatible_brands ID_CLIP_INFO_VALUE2=isomiso2avc1mp41 encoder: Lavf55.12.102 ID_CLIP_INFO_NAME3=encoder ID_CLIP_INFO_VALUE3=Lavf55.12.102 ID_CLIP_INFO_N=4 Load subtitles in c:\movies\ ID_FILENAME=c:\movies\304640436.clipped.mp4 ID_DEMUXER=lavfpref ID_VIDEO_FORMAT=H264 ID_VIDEO_BITRATE=4654776 ID_VIDEO_WIDTH=1920 ID_VIDEO_HEIGHT=1080 ID_VIDEO_FPS=25.000 ID_VIDEO_ASPECT=1.7778 ID_AUDIO_FORMAT=MP4A ID_AUDIO_BITRATE=128536 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 ID_START_TIME=-0.03 ID_LENGTH=8.43 ID_SEEKABLE=1 ID_CHAPTERS=0 <vo_directx><ERROR>Your card doesn't support overlay Opening video filter: [scale] [ass] auto-open Selected video codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [libavcodec] ID_VIDEO_CODEC=ffh264 Selected audio codec: AAC (Advanced Audio Coding) [libavcodec] AUDIO: 48000 Hz, 2 ch, floatle, 128.5 kbit/4.18% (ratio: 16067->384000) ID_AUDIO_BITRATE=128536 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample) ID_AUDIO_CODEC=ffaac Starting playback... VIDEO: 1920x1080 25.000 fps 4654.8 kbps (581.8 kB/s) ID_VIDEO_ASPECT=1.7778 [swscaler @ 02205d80]using unscaled yuv420p -> bgra special converter VO: [directx] 1920x1080 => 1920x1080 BGRA No bind found for key '0x1b '. Exiting... (Quit) ID_EXIT=QUIT
Add
Code:-vcodec copy -acodec copy
Code:ffmpeg.exe -y -i "C:\Movies\304640436.mp4" -vcodec copy -acodec copy -ss 00:00:06.5 -t 8.40 "C:\Movies\304640436.clipped.mp4"
Thank you for your answer.
Do you also know how to accurately cut the video with ffmpeg while doing a bitstream copy ?
The ffmpeg site says :
Code:Seeking while doing a bitstream copy Using -ss as input option together with -c:v copy might not be accurate since ffmpeg is forced to only use/split on i-frames. Though it will—if possible—adjust the start time of the stream to a negative value to compensate for that.
https://forum.videohelp.com/threads/359491-Just-an-idea-ffmpeg-based-key-frame-accurate-cutting
but did not understand their conclusion.
Thanks ! -
would it not be possible to write a program to find the most close I frame (or how else it is called - sorry i do not know the terminology)
and then pass in the -ss parameter the time of this frame as a value ? -
Yes....you will find dozens of them in the TOOLS section....many of them are FREE. They show you exactly where you are cutting and they show/tell you if you can cut there losslessly. They are called Video Editors. AviDemux is my personal favorite.
I'll never understand the fascination with the frustration of Command Line devotees.....especially with simple video cuts. -
If the time doesn't hit a key frame the previous key frame will be used as starting point for the cut.users currently on my ignore list: deadrats, Stears555, marcorocchini
