hello,
can any one help download from :
ProSport
Results 1 to 11 of 11
worked for me
extract RTMPDumpHelper and RTMPDump from ZIPs
copy all files from RTMPDump to RTMPDumpHelper folder
run RTMPDumpHelper.exe and conform that you have this messages:
Go to link video, select 720pHD and click play
wait for message Closing connection... done! in command line window:
Find FLV video file in rtmpdumphelper folder:
If you don't have video file,
refresh video page and again select 720pHD and click play
wait for message Closing connection... done! -
I think Its different type of stream
Try download with FFmpeg, but don't know if its will work for 100%
first you need to get m3u8 link
720p:or 420p:Code:http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/4f02666509404e7ca5a464ebba7b58af/qalam_humra_s01_e15.mpegts/playlist-9f4c8d2ba8e51aa317a8717af70502fd82bc4428.m3u8
Download FFmpeg.exe and copy to C:\Code:http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/ae184036f6c64fa1b960a865b55ab3be/qalam_humra_s01_e15.mpegts/playlist-96bec1be23dd518045b88d072ebf86223d7faf32.m3u8
Open Command line copy paste:
this will download video.ts file to C:\Code:C:\ffmpeg -i "http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/4f02666509404e7ca5a464ebba7b58af/qalam_humra_s01_e15.mpegts/playlist-9f4c8d2ba8e51aa317a8717af70502fd82bc4428.m3u8" -c copy Video.ts
For more info: https://forum.videohelp.com/threads/361161-Need-help-for-download-a-streamLast edited by roma_turok; 14th Nov 2014 at 10:59.
Hi ,
with the instruction : ffmpeg -i "http:... .m3u8"
you can get informations directly without downloading .
See below :
(1) Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720
(2) Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 426x240
Cheers .Code:====== (1) =============== ffmpeg -i "http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/4f02666509404e7ca5a464ebba7b58af/qalam_humra_s01_e15.mpegts/playlist-9f4c8d2ba8e51aa317a8717af70502fd82bc4428.m3u8" Input #0, hls,applehttp, from 'http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/4f02666509404e7ca5a464ebba7b58af/qalam_humra_s01_e15.mpegts/playlist-9f4c8d2ba8e51aa317a8717af70502fd82bc4428.m3u8': Duration: 00:42:46.47, start: 9.953556, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 194 kb/s ====== (2) =============== ffmpeg -i "http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/4f02666509404e7ca5a464ebba7b58af/qalam_humra_s01_e15.mpegts/playlist-9f4c8d2ba8e51aa317a8717af70502fd82bc4428.m3u8" Input #0, hls,applehttp, from 'http://l3md.shahid.net/media/l3/2fda1d3fd7ab453cad983544e8ed70e4/d3d47396cf3c43bda4380bfacb7ba708/ae184036f6c64fa1b960a865b55ab3be/qalam_humra_s01_e15.mpegts/playlist-96bec1be23dd518045b88d072ebf86223d7faf32.m3u8': Duration: 00:42:46.47, start: 9.953556, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 426x240 [SAR 1:1 DAR 71:40], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 64 kb/s =======================JE SUIS CHARLIE !!! -
Of course I don't mean you need download to see what resolution
I meant when its start download you can see resolution then you can close it
or stay open if you want to download
