Hi,
I am newbie here.
I need help to download this URL :Code:http://shahid.mbc.net/ar/episode/71400/WWE-RAW-%D8%A7%D9%84%D9%85%D9%88%D8%B3%D9%85-5-%D8%A7%D9%84%D8%AD%D9%84%D9%82%D8%A9-15.html
I tried rtmpdumphelper and rtmpexplorer
But NOT WORKING ....
Thanks!
Results 1 to 12 of 12
use ffmpeg
360p 1296kbps
360p 696kbpsCode:ffmpeg -i "http://akmd.shahid.net/media/ak/2fda1d3fd7ab453cad983544e8ed70e4/635cd1af2edd4362a067fdb2f7358ab0/110b585761264616ab53edafc51f62f4/wwe-raw-2013-2014_s05_e15_vod.mpegts/playlist-fd0c463d3c973ef099401ae8bc3f363099742621.m3u8" -c copy t.ts
224p 496kbpsCode:ffmpeg -i "http://akmd.shahid.net/media/ak/2fda1d3fd7ab453cad983544e8ed70e4/635cd1af2edd4362a067fdb2f7358ab0/2cb69c30ebc64a1f9f3aef03f67cfc53/wwe-raw-2013-2014_s05_e15_vod.mpegts/playlist-08cfd7fd83d9e81d9416816ad6b757505deee695.m3u8" -c copy t.ts
224p 206kbpsCode:ffmpeg -i "http://akmd.shahid.net/media/ak/2fda1d3fd7ab453cad983544e8ed70e4/635cd1af2edd4362a067fdb2f7358ab0/2a9773982922474f8725b6df11bc1a2b/wwe-raw-2013-2014_s05_e15_vod.mpegts/playlist-29ae178374b29a415200d18919ba33f156af3ba9.m3u8" -c copy t.ts
Code:ffmpeg -i "http://akmd.shahid.net/media/ak/2fda1d3fd7ab453cad983544e8ed70e4/635cd1af2edd4362a067fdb2f7358ab0/87c311a7fd5340dfb1c8df8bc82261a2/wwe-raw-2013-2014_s05_e15_vod.mpegts/playlist-68c50bafb1f06f05acb98eb15cfb666883c55919.m3u8" -c copy t.ts
oh think you CristianoA
but if may ask . how did you find those links ?
and thank you again -
HEllo
How can i download this video
http://shahid.mbc.net/ar/episode/71479/The-Voice-%D8%A7%D9%84%D9%85%D9%88%D8%B3%D9%85-...2%D8%A9-1.html
Gilbert -
this guys use geo-blocking.
Code:ffmpeg -i "http://xdnmd.shahid.net/web/mediaDelivery/media/6868d1e486034d7180ddcc31af84f5d0.m3u8" -c copy output.ts ffmpeg version N-58115-g150c554 Copyright (c) 2000-2013 the FFmpeg developers built on Nov 15 2013 18:07:27 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 53.100 / 52. 53.100 libavcodec 55. 43.100 / 55. 43.100 libavformat 55. 21.100 / 55. 21.100 libavdevice 55. 5.100 / 55. 5.100 libavfilter 3. 91.100 / 3. 91.100 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 17.104 / 0. 17.104 libpostproc 52. 3.100 / 52. 3.100 Input #0, hls,applehttp, from 'http://xdnmd.shahid.net/web/mediaDelivery/media/6868d1e486034d7180ddcc31af84f5d0.m3u8': Duration: 01:23:48.48, start: 9.976778, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 496000 Stream #0:0: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 398x224 [SAR 1:1 DAR 199:112], 25 fps, 25 tbr, 90k tbn, 50 tbc Metadata: variant_bitrate : 496000 Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 111 kb/s Metadata: variant_bitrate : 496000 Program 1 Metadata: variant_bitrate : 206000 Stream #0:2: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 398x224 [SAR 1:1 DAR 199:112], 25 fps, 25 tbr, 90k tbn, 50 tbc Metadata: variant_bitrate : 206000 Stream #0:3: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 111 kb/s Metadata: variant_bitrate : 206000 Program 2 Metadata: variant_bitrate : 696000 Stream #0:4: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Metadata: variant_bitrate : 696000 Stream #0:5: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 111 kb/s Metadata: variant_bitrate : 696000 Program 3 Metadata: variant_bitrate : 1296000 Stream #0:6: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Metadata: variant_bitrate : 1296000 Stream #0:7: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 111 kb/s Metadata: variant_bitrate : 1296000 Output #0, mpegts, to 'output.ts': Metadata: encoder : Lavf55.21.100 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 25 tbc Metadata: variant_bitrate : 696000 Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, 111 kb/s Metadata: variant_bitrate : 496000 Stream mapping: Stream #0:4 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 27 fps=0.0 q=-1.0 size= 95kB time=00:00:01.13 bitrate= 682.1kbits/s frame= 30 fps= 23 q=-1.0 size= 119kB time=00:00:01.25 bitrate= 778.5kbits/s -
Anyway can we download this ?? http://tinyurl.com/o37c6wx possibly in the highest quality
How to download stream over RTMPS protocol?
By Muratso in forum Video Streaming DownloadingReplies: 5Last Post: 13th Mar 2014, 07:08 -
Stream Download
By Rulez in forum Video Streaming DownloadingReplies: 1Last Post: 21st Nov 2013, 16:36 -
I cannot download a stream Capture
By neroman00 in forum Video Streaming DownloadingReplies: 12Last Post: 28th Jan 2013, 07:03 -
Would you stream or progressive download given my needs??
By Remi T in forum Video Streaming DownloadingReplies: 5Last Post: 12th Dec 2010, 10:10 -
How do I download this stream/vid?
By Frank005 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Jan 2009, 16:35
