  1. I was Rpping Some Of My Old DvDs Using Megui
    I Found I get These Type In Edges At fast Movements/actions
    1)Suggest Any Good/Effective AViSynth Plugin to fix this
    On Movements
Name:	8-10-2014 - Wednesday 1-23-18 AM.jpg
    Name:  8-10-2014 - Wednesday 1-30-26 AM.jpg
    While Not Moving(Perfect) [I Need This Type Of Fix]
    Name:  8-10-2014 - Wednesday 1-31-32 AM.jpg
    So i Need Fix this How can i ???
    2)Additionally i need Some Good block Fixing Plugin Too [Fix The Below Like Looking Blocks On Videos]
    Everything Should work With Megui
    Becaz i Use That only
    Help Me !
    [1nly If] sry fr My Bad eng
  2. Do you run an analysis with MeGUI and is the video interlaced or progressive etc?
    If the video is interlaced, try using QTGMC for de-interlacing (instead of Yadif etc).
    QTGMC()
    If the video is progressive, you can still try QTGMC, but in progressive mode.
    QTGMC(InputType=1)
    May 2014
    Memphis TN, US
    Same questions. What's the nature of your "videos"? We need more information.
    The top two images show dark and bright halos, plus aliasing usually caused by improper deinterlacing. The third image down has oversharpening halos. The bottom image shows improper interlacing and block noise caused by poor encoding (bitrate too low).
    We need to see some unprocessed samples of your original source(s). We'd also like to know what you're trying to do.
    - My sister Ann's brother
  4. Originally Posted by hello_hello View Post
    QTGMC()
    QTGMC(InputType=1)
    Yep I started A thread QTGMC Deinterlacing https://forum.videohelp.com/threads/367636-I-Need-Perfect-Help-QTGMC-Deinterlacing-Script-On-MeGui
  5. Originally Posted by LMotlow View Post
    I m Just Tryingt To Upscale Videos In Order To View onMy HD-TV
    It Look So Embarssing But I need to Bring Some Decent Quality
    I tried DE-BLOCK Script I worked Well To Some Extends..
    I need To Is there Any Good DEBLOCKERS
    Analyzis Result
Name:	10-10-2014 - Friday 10-51-35 PM.jpg
    May 2014
    Memphis TN, US
    DeBlock might help with some macroblocks, but it won't help aliasing or the other artifacts.
    - Upscaling from what? Here's the bad news. Resizing has a quality cost. Always, more or less, the damage depending on how it's done.
    - If you're upscaling SD to HD, prepare for a disappointment.
    - Don't use Lanczos. It sucks. If you think you have oversharpening halos and other artifacts, wait til Lanczos gets through with it.
    HD has different requirements in frame structure and a lot of other elements. Just resizing isn't enough. We still don't know what kind of source video you're working with. So there's not much advice anyone can offer.
  7. Originally Posted by LMotlow View Post
    I m Working On My Home DvD Videos
    If I provide Sample can u able give me best/Better AviScript For Upscaling??
    SD to HD = disappointment.
    Yes! U r Right But Some Decent Qulty Bring Know Only That I m Looking For..
    Is Tht Possbile???
  8. Originally Posted by arcte View Post
    Your television is perfectly capable of upscaling, and probably better than you.
    If the quality is crap to begin with, it'll still be crap whether you or the television do the upscaling. Do you have a sample from your source DVD so we can have a look?
