  1. I know that i can extract the streams from the MP4, covert the audio and then create another MP4 from those streams. But i was wonderign if there is a way to do this in a more automated fashion. Such as a command for ffmpeg that i could maybe run as a batch command? The problem i have is that i have many MP4s that i need to do this with, so doing each one manually is an extremely time consuming process.
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Bad idea.....
    Mp4 should use aac not ac3.
    See https://forum.videohelp.com/threads/356314-How-to-batch-convert-multiplex-any-files-with-ffmpeg
    and the batch something like
    for %%a in ("*.mp4") do ffmpeg -i "%%a" -c:v copy -c:a ac3 -b:a 224k "newfiles\%%~na.mp4"
    pause
    224k is the audio bitrate.
    But why do you need ac3?
  4. Originally Posted by racer-x View Post
    Bad idea.....
    The files won't be staying as MP4, they will be converted to blu rays. The reason for needing the change in audio is due to a problem i found occuring over and over. When trying to author a blu from the MP4 files as is, i always end up with audio sync issues. I did however find a work around for this. Which is to extract tge streams, convert the audio and the create an MP4 again. That MP4 when converted to blu has no audio sync issue.
