Page 20 of 27
FirstFirst ... 10 18 19 20 21 22 ... LastLast
Results 571 to 600 of 789
  1. I think the effect is scriptable, and probably someone has the script (probably in Japanese).
    (Maybe it is in the bundled installer, I just don't bother to try out every effect)
    Doing it layer-by-layer is impractical for longer text.
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
  2. Another slightly easier way is with animation effect=> Stretch@ANIM2-EN , which essentially controls a mirror split - so that effectively cuts the number of layers in half
    @Maverick - any English guides or examples on aviutl scripting ?
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    It can be done using one layer if you enable "1char1obj", then apply the "Scale Coordinates" animation filter.
    P.S. Mine looks a little funny because I'm running it in Linux under Wine......
  4. @racer-x
    you nailed it, gj and thanks!
    @PDR
    look for the bundled LUA.txt or on my blog:
    http://mavericktse.mooo.com/wordpress/archives/1188
  5. hello, i was wondering if someone can help me, my friend use aviutl and he has the same aviutl as me, but he has many effects for texts as Click vibrate or something and I have not those ones, can someone tell me where or how i can find those effects?
  6. Member racer-x's Avatar
    Mar 2003
    Add a Flter Effect > Animation Effect. The Vibrate filter should be the first one activated. Adjust parameters as needed......
  7. Member racer-x's Avatar
    Mar 2003
    It will vibrate the letters individually if you tick "1char1obj"
  8. So much thanks, this helped me a lot!
  9. Hello all.
    I have 170 MTS clips. How to import them directly into the timeline, all once not one by one. Also how do I automatically transitions?
    Thank you,
    Best regards
    Tavi.
  10. In the Utility folder, there is a SlideShowHelperEN.exe for making still-image based slide show. You can try that on the MTS also but not guarantee to work.
    The resulting file is an EXO, you will need to right-click on Adv. Editing panel and import the file there.
  11. Thank you for replay.
    Excelent idea but it's not working good. The program reduce all video to some lenght and no audio. Can you modify the program to work corectly for video ?
    Thank you,
    Best regards.
    Tavi.
  12. Sorry I'm not going to make another program for this. (It is not as easy as to "modify" the existing program, since video has variable length)
    AviUtl has facility to join up a batch of AVI, but not adding transition effect at the same time.
    I'd suggest making a new post on the Video Editing Board to ask for help. You'll need other tools to do that if there are any.
  13. The source code for almost all plugin/utilities made by me has been uploaded to github:
    https://github.com/MaverickTse?tab=repositories
    if any developer feeling adventurous, feel free to take the code and study them.
    (P.S. The code looks procedural and not very OOP... so they looks messy)
  14. Thank you for replays.
    A last question, can i ask where is "join up a batch of AVI" ?
    I wish to use your great soft only to join some MTS with transition and text.
    Regards,
    Tavi.
  15. File> AVI files (the item above "Recent files") > Link AVI
    You need to name your AVIs as number beforehand like 0001.avi, 0002.avi,... 0099.avi
  16. One more reason for the 0xC0000005 Access violation error discovered.
    This cause not only affect AviUtl, but also some games and Visual Studio:
    The Asus Audio Panel.
    Put it in layman's term: Semi-compatible drivers in Win10
    Details:
    http://mavericktse.mooo.com/wordpress/archives/2358
    (I've never aware that exception error can affect across different programs)
  17. Originally Posted by MaverickTse View Post
    MTS can not automatically add sites in the timeline. But the compressor h264 is excellent programming for compression, quality is great. In my opinion the program needs some kind automated insertion clips in the timeline and not one by one. Event and adding automatic transition. Here I stop testing program. Thanks for explanations and collaboration.
    This is a translation by google translate, sorry for translation.
    Best Regards
  18. Originally Posted by Taviro View Post
    Best Regards
    Sorry I don't think your need is a common one. You'll probably need some specialized Encoder GUI, AviSynth or FFmpeg
  19. Greetings.
    In the end I used Adobe Premier, exported DNxHD 250MB / s (1h = 130Gb) and transcoded with Aviutl. The result is perfect. Final movie (50p,20Mbps) has original film quality (50p,28Mbps). Loss of quality is 1-2%.
    Aviutl encoder is the best I've used so far (x264, 8bit).
    Thanks so much for this program.
    Respectfully.
    PS: sorry for english..google translate.
    PPS: muxer.exe hang at end.
    Oct 2011
    Spain
    When I open an MP4 video file with Aviutl I receive this message: "[Warning]: Detected CTS duplication at frame 3". After that the program seems to work well, but then I have issues when exporting. I'm discussing the whole thing in another thread, but I'd like to know if this warning message is something to worry about.
  21. Recently I received two reports on x265 being failed to download.
    Currently looking into the issue.
  22. just released Installer 1.13 to fix the broken links permanently.
    x264 and x265 files are now hosted on a dedicated dropbox account, so the DL URL should not change.
  23. How can I export with the best resolution?
  24. Best resolution??
    When you create a project you're given the option to set the resolution
    Name:  Screenshot - 7_18_2016 , 11_06_09 PM.png
    Should you want to change it you can use the tool window
Name:	Screenshot - 7_18_2016 , 11_03_50 PM.png
  25. There is no such thing as best resolution.
    There are recommended resolution for certain purpose however.
    Typically HD (1280x720) or FullHD (1920x1080) would be enough, some video site may require lower setting.
  26. ah, export...
    I guess you mean "quality", not "resolution"
    the resolution is the same as your project, unless you use FFmpegOut to resize the video during encode.
    For quality, if you use x264GuiEx, under default settings, just pull the main slider to the left until crf= 17.
    or save as AVI, which gives you a huge file that is loseless.
  27. Anyone experience problem with iTune download?
  28. Originally Posted by MaverickTse View Post
    Not with the iTune.
    I just downloaded AviUtl Extra Pack 1.13 and during installation i got the error "...x265_10bpp.exe does not exist"; I ignored it to continue because I don't use x265.
    Cheers.
  29. Originally Posted by metalorn View Post
    Not with the iTune.
    Cheers.
    Can't reproduce your error. Maybe your connection being unstable or anti-virus deleted it silently.
  30. Hello, I am new to video editing and AviUtl, and so far I've had a lot of fun playing around and reading the available tutorials. Thank you Maverick for making this program available in English!
    I have a few questions I'm hoping can be answered. Please excuse them if they are dumb, I am hoping to learn more about this program and video editing in general.
    1. I've read through the GUI guide but it didn't seem to cover the Tool Window (which popped up when I first opened the program). Are the filters here different from the ones you add to the timeline? Also, if someone could enlighten me as to what the buttons at the top do that would be greatly appreciated. Here is the screenshot: http://3.1m.yt/wm3dBrW.png
    2. The guide and video tutorials have a playback window, but in the version I downloaded (extra pack 1.13) the playback window is just 3 buttons without the screen? I'm not sure if the playback window is only an older feature or if my installation went wrong somewhere...
    3. I was trying to open some of the sample files, but ended up getting this error: http://3.1m.yt/KtSbWse.png
    I don't know if I'm suppose to click yes or no, but more error boxes with similar unreadable text pops up afterwards and then the entire program crashes. I don't know what the error text says so I'm hoping for some help?
    Sometimes when fiddling around with the different animation effects, I get a similar error pop-up box, though I'm not entirely sure if the text is the same since it only happens occasionally. In those cases, the program also crashes.
    4. Would project files made on the Japanese version of AviUtl work if I try to open them in the English version, and vice versa?
    5. Lastly, sorry for my inexperience, but I'm kind of lost on how to install some of the scripts linked here. Using the Animated Gif Export Pack as an example, there's also a "Src" folder along with .dll files that are all in the "AGifExportPack" folder, so do I place the entire "AGifExportPack" folder under the root menu, or just everything that's inside it? Do I have to extract everything in the "Src" folder to the root menu as well, or just the "Src" folder itself? Again, sorry if this is really dumb, but I am not very computer savvy...
