Results 1 to 14 of 14
    Nov 2013
    Planet Earth
    I have used quite a number of DVD creator softwares but can't get them play like normal DVD movies. I can't play my burned DVD on my older DVD player. I had use Xillisoft, imToo, Aimersoft example, and the only software that works fine with any DVD player is DVD Flick.
    But for DVD Flick, I am not sure why am I getting a purple video after burning my video It looks like a colour distortion in my video. Here are my settings.
    Format: Mixed (Determine whether NTSC or PAL and encode as such for best quality)
    Bitrate: 8000 Kbit/s
    Encoding: Normal
    Does anyone know how can I burn my DVDs such that it will play on any DVD players like normal DVD movies, and how to solve this colour distortion in my video?
    Nov 2003
    West Texas
    Try AVStoDVD instead. And burn the output with ImgBurn.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If your place on Planet Earth is somewhere in North America, why are you even mentioning PAL?
    Feb 2014
    QUÉBEC
    AVStoDVD or ConvertXtoDVD. your two best options IMO
    Nov 2013
    Planet Earth
    AVStoDVD is not related to AVS Disc Creator right?
  6. Did you click the link to find out what it is? So far you've used garbage. Now try a good program for a change. Well, DVD Flick is passable, I suppose.
    But to answer your question, no it's not related to AVS Disc Creator (whatever that is).
    Nov 2013
    Planet Earth
    Ok. I will try those software. But for ImgBurn, which one to choose after getting the output from AVStoDVD?
    Mar 2008
    You choose write files/folders to disk, then drag in the video_ts folder.
    Nov 2013
    Planet Earth
    Ok I am getting this errors while using AVStoDVD. When I click on the menu, it gives me this message.
    Then I got this error,
    and it hangs when loading the menu editor.
    What's wrong with the software?
    PS: This error pop out with both the installed version and the portable version.
    Nov 2013
    Planet Earth
    Any solutions?
    Nov 2003
    West Texas
    AVStoDVD has proved to be an excellent program, with very few issues. I have used it for years and have never seen the error messages you've posted.
    So talk to the author directly: https://forum.videohelp.com/threads/277852-AVStoDVD-Support-Thread/page68
    Nov 2013
    Planet Earth
    Ok Thanks!
    Nov 2013
    Planet Earth
    I had recently tried DVD Flick v2 and it is giving me a strange error I never encounter before. "xxxxxx.mkv has no usable video track. It will not be add to the project". I had no problems with .mkv videos with the official DVD Flick 1.3.0.7. Why is this happening in the new 1.3.0.9 v2? v2 should improve it not make it worse.
    Nov 2013
    Planet Earth
    Any Ideas???
