  1. Hi,
    I know that eac3to can extract raw wave files separately for each channel from an audio track. I would like to know which GUI to use and the steps to do so. I am not very good with command lines. I've tried few GUIs but either they didn't have the option or I simply couldn't figure out a way.
    Also, does eac3to also process the MLP data of the HD audio while trying to create the wave files?
    I have DTS-HD Master Audio Suite for creating lossless audio using wave files. Which software can be used for Dolby TrueHD?
  2. Audacity with the ffmpeg plugin can import multichannel audio. You can the export each track separately if you want.
  3. Originally Posted by jagabo View Post
    Thanks. By each track do you mean each channel individually like Front: L C R, Side: L R, LFE ?
    Also, any idea about eac3to. It's very fast.
  4. Originally Posted by maxrockpro View Post
    Yes.
  5. commandline for eac3to is actually much easier, but follow the steps in this post, there are screenshots and step by step instructions, along with a link for the old GUI version that more people prefer
    https://forum.videohelp.com/threads/300964-Help-Split-6-Channels-into-separate-WAVs
    Dolby Media Encoder
    http://www.dolby.com/us/en/professional/software/bluray-and-dvd-content-creation/dolby...er-client.html
