Results 151 to 180 of 198
muffinman123Guest
here's a problem that crashed the program. when I right click add a temporal denoise filter on the timeline, it either gives me a black screen, or it crash the program. am I supposed to add filter through the timeline bar or through the main screen filter menu?
can someone tell me how the filters work?
on the main screen there's filter and filter+, but in the time line bar you can also right click and add filter objects.
how do these 2 methods affect each other? the main screen filter menus don't seem to affect the video in real time, only the timeline filer objects do, so are they applied during processing?Last edited by muffinman123; 26th Aug 2014 at 07:24.
[Filter] menu serves as a quick ON/Off switch.
[Filter+] will pops up a setting dialog (enable/disable by checking the little box on top-right corner)
On the NLE, Avoid all "Filter objects" that also appears in main menu (Filter/Filter+).
The NLE is actually a filter like the Delogo and NL-Means. Some filters will only work on videos loaded through AviUtl main program while not working as expected if loaded through NLE. You may also need to change the Filter Order (Filter+ > Filter order)in order to achieve the desired effect.
Using Filter+ with the NLE simultaneously is not recommended excepts simple resize operation. -
muffinman123Guest
so does the main filter menus only work on videos loaded through the main screen? or does it also work on the timeline bar videos when I output the videos? is there a way to preview the main menu filter results?
if I am outputting videos using x264, is there a way for me to resuse the stats and mbtree files as template to speedup somehow? say I didn't change the video orders but added other filters like color correction and denoise and stuff, is there a way for me to take old stats into account when encoding?Last edited by muffinman123; 26th Aug 2014 at 15:28.
There is no way to reuse the stats / mbtree . Since you changed the filters, it's effectively a different video anyways to x264, so you wouldn't want to reuse them
If you are using multi-pass and want to keep those stats files:
In the encoder GUI, Click [MISC] > [Auto multi-pass] tab, and uncheck "Delete status file automatically".
Does it reuse old stats file? I don't know, haven't tried it myself.
If you are on a 64-bit Windows, you can point the GUI to use a 64-bit version of x264 that you may download separately. The bundled x264-8bpp is 32bit build. The 64-bit x264 should work faster, but your mileage may vary. -
muffinman123Guest
All? Nope. I have written on some commonly used functions however:
http://mavericktse.mooo.com/wordpress/the-unofficial-aviutl-guides
see section A for those global filter functions.
Many slider settings have mysterious functions(or simply way too technical)... so a full documentation is difficult.
You may share you findings in this thread:
https://forum.videohelp.com/threads/366724-Aviutl-Tips-Tricks-and-Support-thread
but I don't have the energy to do all the controlled experiments to find out which parameter does what...not getting paid anyway. -
muffinman123Guest
do you know what the advanced color correction filter does? in the lower boxes, it has a tv to pc conversion and vice versa, and it seems to work pretty well for me. I have no idea why though.
Maybe this can explain: http://en.wikipedia.org/wiki/Color_matrix
Basically PC = PC range 0-255, TV = TV range 16-235.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
muffinman123Guest
aviutl seems to be able to read my project files on a windows 8 computer with no codecs installed at all other than native ones. it uses libdev smash reader to do it so it takes a long time to load the files. that's fine though, as long as it works I am all good.
but I came across another problem, the program also crashes because ntdll.dll for avi/avi2 reader seems to fail every time it reads a specific file in my directory. so far my temporary fix is to move avi/avi2 reader to the bottom of the priority list and hope aviutl never uses it, but I have no idea what's causing the crash because the message is in japanese and my computer doesn't have the font to display the error.Last edited by muffinman123; 27th Aug 2014 at 19:54.
muffinman123Guest
in here it mentioned using nnedi3 as resize filter, but I looked at the nnedi3 filter and it only process the frame without changing the size.
how do I use nnedi3 to upsize in the timeline bar? my other graphics are already upsized, so I guess what I will do is load each video and then upsize using advanced editing.Last edited by muffinman123; 27th Aug 2014 at 20:40.
Please post in this thread:
Together with the MediaInfo analysis report of your AVI file in concern. -
muffinman123Guest
obsolete, message removed.
muffinman123Guest
so there's "change size", "clipping and resize", and "resize filter", but "change size" and "clipping and resize" don't mention what method they use to do the resizing.
EDIT:
alright, I just understand what you meant, so I am using nnedi3 to upsize by rfactor, but you mentioned that rfactor needs to be 2 or 3. when I checkmark the "use as upscaling filter". rfactor kept getting stuck at 0 and 1, what do the settings do when nnedi3 is used for upscaling?
I heard that nnedi3 introduces center shift, does the aviutl plugin already have the solution builtin for this problem?
and then I need to downsize to get to the aspect ratio I am looking for, which filter should I use to go with nnedi3?
ahh so close to figuring this out, I just need to figure out the order of upsizing with nnedi3, downsizing with method yet unknown, and figure out which order to put denoise spatial and temporal, and also ringing cancel and advanced color correction.Last edited by muffinman123; 28th Aug 2014 at 03:53.
You are not paying attention enough... at least in the "resize filter", there are a number of methods: Sinc, Area average, etc.
For other resize plugins, assume the simplest linear interpolation.
NNEDI resize in x2, x4, x8... if your original image is already quite large and the resulting image would exceed 1920x1080(in any one dimension), the rfactor slider stuck.
You can loosen this limit at FILE>SETTINGS>SYSTEM
Center Shift: last slider
For significant upsampling(double size or above), NNEDI3>resize filter(area average)>clipping -
muffinman123Guest
regarding volume normalization, what does the slider value mean? I output a wave file with normalization values at 192 and 128, and I couldn't really tell the difference.
Stopping development until someone save me from poverty or get me out of Hong Kong...
Twitter @MaverickTse -
Sorry I am late to the game. Guth's deshaker 3.1 needs virtualdub for pass1 for sure.
@MaverickTse: Dude, your sites link to virus :O I wanted to download your subtitle removal tool and try it out, but Avast blocked the entire site with URL:Mal infection alert. The virus is on hxxp://69.6.223.30/wordpress/archives/1403 (disabled link generation). You should clean up your sites in order to make your sites available to most people...
It is Avast's fault. It is a known false positive.
There is another subtitle remover that shouldn't provoke the AV alert:
http://mavericktse.mooo.com/wordpress/archives/2053Stopping development until someone save me from poverty or get me out of Hong Kong...
Sorry, result is too noisy. Looks like I have to find another version of the movie
Hey there,
I'm wondering if there's a good way to have an object follow a path like in Flash (at least the old Flash, not sure about now).
I want to have an image in the background and only mask a portion of it like a mystery sort of thing.
A path like random zigzag with a round (or anything) see-through mask that moves around the screen showing a portion of the image.
Is that even possible?
Thanks Wizzards.
aviutl.exe no longer opening
By MLS in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2011, 15:11 -
Help needed with AviUtl 0.98d – can’t read menus
By MLS in forum EditingReplies: 0Last Post: 16th Jul 2011, 03:19 -
video tutorial?
By greatveemon in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2011, 08:20 -
Need tutorial for video making
By mazeer in forum EditingReplies: 1Last Post: 5th Jan 2011, 07:32 -
Video Capturix 2008 tutorial
By avz10 in forum Video ConversionReplies: 3Last Post: 16th Mar 2009, 14:30
