Results 1 to 14 of 14
  1. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Maybe I'm losing it or the GUI has changed, but I had to go back to MKVToolnix 6.4.1 as 6.5.0 is missing the properties window when you add files. Because of this the file properties are all greyed out so I can not load the timecodes for my VFR streams. Any feed back would be great. See attached photos for a visual:
ID:	20680Click image for larger version
    if all else fails read the manual
  2. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Whew, may be crazy still but now I know it's not just my rig.
  3. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Tried stretching across the countryside and clicking all in the program, no go on this end. 6.4.1 has proper OPUS support so I can wait until this is fixed
  4. DECEASED
    Jun 2009
    Heaven
    LOL.
    Mosu had just released a new binary, so even that doesn't work?
    I haven't tested it yet, I'm quite satisfied with version 5.8.0, and still waiting for the HEVC-support thing
  5. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    tried the link here and the one in your post, same file
  6. DECEASED
    Jun 2009
    Heaven
    Hmmm, it seems you're partially right...
    BTW, what's the resolution of your monitor?
  7. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    1366x768, not near my 1080p right now...should be plenty of resolution anyway though
  8. DECEASED
    Jun 2009
    Heaven
    Not if the GUI was somehow royally misdesigned
    Anyway, here goes a pic of the ACTUAL fixed binary:
  9. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Thanks Baldrick and El Heggunte, works on my laptop. Figured something like this would be caught by quality control before realease lol. Consider this thread closed.
  10. Hi after this update the computer is hanging and it is so slow. Hope this gets resolved soon sticking to the old version for now. Hate the new one for the fact that it makes the pc lag ... While it converts the video to mkv.
  11. DECEASED
    Jun 2009
    Heaven
    https://forum.videohelp.com/threads/359652-MKVMERGE-GUI-slower-than-version-5-8
