I have been using MkvMerge GUI 5.8 and recently uninstalled it and installed the latest version (6.5). I noticed that muxing takes much longer than version 5.8. Ha anyone else noticed this?
Results 1 to 10 of 10
haven't really checked, but it wouldn't surprise me since the mkv format gets extended more and more (to in example be able to support new audio&video formats), thus the structure gets potentially more complex,..
Just for the notes --- a random
file, remuxed with MMG 5.8.0, required 26 seconds;
the same file, remuxed with MMG 6.5.0-1, required 28 seconds ;
PERHAPS there is a regression in the GUI (not in mkvmerge itself),
and in this case, please goto http://www.bunkus.org/videotools/mkvtoolnix/bugreports.html ,
since the author of MKVtoolnix is not a regular visitor of Videohelp
(afaik, at least).Last edited by El Heggunte; 20th Oct 2013 at 16:45. Reason: stupid typos
I checked the page for bug reports and it doesn't mention a mail to send. I think i will go back to version 5.8. Same result but quicker.
visual quality:
no
compatibility:
to newer formats and different players, depending in the settings: yes
-> personally, would stick with the newer versions and report issues to Moritz -
El Heggunte for a 10GB MKV file while the 5.8 version took about 2 minutes and 25 seconds, in the 6.5 it requires about 3 minutes and 10 seconds. Not a small difference.
Thanks for confirming the problem
OTOH, my name IS NOT Moritz Bunkus
http://www.bunkus.org/videotools/mkvtoolnix/contact.html
using mkvmerge gui
By zoloabc in forum EditingReplies: 8Last Post: 26th Jun 2014, 12:44 -
MKVMerge GUI won't works.
By amiynwahid in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2012, 05:26 -
MKVMerge GUI Suddenly Not Working
By ZodiacBeast in forum EditingReplies: 3Last Post: 16th Sep 2012, 22:42 -
mkvmerge GUI 4.4.0 Vs mkvmerge GUI 2.0.2
By Manospetrucci in forum Video ConversionReplies: 2Last Post: 6th Jan 2011, 20:34 -
Trouble with mkvmerge gui
By nzdreamer55 in forum EditingReplies: 0Last Post: 25th Nov 2010, 13:07
