  1. https://forum.videohelp.com/threads/340817-Sound-System-wid-PCThis is the thread where the members of this forum helped me out, with the problem.
    Now i have problem with the same system.
    Out of 5 speakers only 1 is working properly, rest are not working.
    I had checked each speakers separately, that time they were working fine.
    But when i connect it to the sound System they dont work.
    I dont know where the problem is.
    Can anyBody help me out
  2. DECEASED
    Jun 2009
    Heaven
    If the speakers themselves are good, but they don't work when connected to the sound system,
    then I conclude the problem is in this latter.
  3. Member Cornucopia's Avatar
    Make sure you have a source test file that is outputting on ALL channels. And make sure your sound system is set to bypass any additional processing which could affect playback.
    Since, in your other post you stated that ALL 5 of your speakers were working perfectly, it could be your system has now finally died. I hate to say it, but given the (pictured) state of the equipment I am not surprised.
  4. Originally Posted by Cornucopia View Post
    What is source test file ?
    & if the system was dead, then how could only 1 speaker work.
    & that too not just a specific speaker any of the speaker works at any given time.
  5. DECEASED
    Jun 2009
    Heaven
    Multichannel test file => a short, 5.1 or 6.1 or 7.1 file that activates only one speaker at a time.
    OK, the sound system may still be "alive", but apparently it's not working as expected anymore.
    Can't you let a technician take a look at the problematic device?
    BTW, I guess the fixing, if possible, would not be worth its price.
  6. Originally Posted by El Heggunte View Post
    yaa thats the problem
    If i think of replacing that system, what are the options ?
    Are there any kinda thing available ?
    & what would be the cost ?
    So that i can connect the speakers to it & then to my computer
  7. Member Cornucopia's Avatar
    ebay.
