    Oct 2013
    North Carolina
    Recently I have had problems with TMPGEnc Video Mastering Works not opening Xvid.avi files I want to convert..... It will load the file and when I got to edit the file I just get a black screen but the audio is fine. I just downloaded the most recent XVID a couple weeks ago, I don't know if that has anything to do with it or not....Divx files loads fine, the Xvid files are the problem. Here is a the media info on a couple of the movies:
    General
    Complete name : C:\XXXXXXXXX (Xvid)
    Format : AVI
    Format profile : OpenDML
    File size : 1.37 GiB
    Duration : 1h 10mn
    Overall bit rate : 2 770 Kbps
    Writing application : MEncoder dev-SVN-r28132-4.0.1
    Writing library : MPlayer
    Video
    Format : xvid
    Codec ID : xvid
    Duration : 1h 10mn
    Bit rate : 2 500 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate : 29.970 fps
    Standard : NTSC
    Bits/(Pixel*Frame) : 0.241
    Stream size : 1.24 GiB (90%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 10mn
    Bit rate mode : Variable
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 129 MiB (9%)
    Alignment : Aligned on interleaves
    Interleave, duration : 24 ms (0.72 video frame)
    Interleave, preload duration : 558 ms
    Movie #2
    General
    Complete name : C:\XXXXXXXXXXXXX (Xvid)
    Format : AVI
    File size : 746 MiB
    Duration : 1h 22mn
    Overall bit rate : 1 258 Kbps
    Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
    Writing library : VirtualDubMod build 2178/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 1
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Custom
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 22mn
    Bit rate : 1 141 Kbps
    Width : 576 pixels
    Height : 432 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.191
    Stream size : 677 MiB (91%)
    Writing library : XviD 1.3.0.dev55
    Audio
    Format : MPEG Audio
    Mode : Joint stereo
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 22mn
    Bit rate : 104 Kbps
    Nominal bit rate : 128 Kbps
    Stream size : 61.7 MiB (8%)
    Interleave, duration : 24 ms (0.58 video frame)
    Interleave, preload duration : 569 ms
    Writing library : LAME3.98r
    Encoding settings : -m j -V 4 -q 2 -lowpass 17 --abr 128
    Computer Specs:
    System Information Report
    General
    Operating System Microsoft Windows 7 Home Premium
    Central Processor AMD FX(tm)-6100 Six-Core Processor
    User Name Larry
    Graphics
    Video Adapter AMD Radeon HD 7450
    Video Memory 1.00 GB
    Screen Resolution 1440 x 900
    Storage
    Total Memory 15.97 GB
    Free Memory 13.01 GB
    Total Hard disk 3334.68 GB
    Free Hard disk 2866.56 GB
    I/O
    Mouse USB Input Device
    Keyboard Microsoft eHome Remote Control Keyboard keys
    Computer System
    Computer Name LARRY-HP
    User Name Larry
    Organization Hewlett-Packard Company
    Operating System
    OS Name Microsoft Windows 7 Home Premium
    OS Version 6.1.7601
    Service Pack 1.0
    Product ID 00359-OEM-8992687-00010
    System Up Time 10/6/2013 2:32:22 PM
    Internet Explorer Version 9.10.9200.16618
    Microsoft DirectX Version 4.09.00.0904
    OpenGL Version 6.1.7600.16385 (win7_rtm.090713-1255)
    Registry
    Maximum Size 2048 MB
    Current Size 135 MB
    Status OK
    Central Processor
    CPU Name AMD FX(tm)-6100 Six-Core Processor
    Code Name Model 1, Stepping 2
    Manufacturer AuthenticAMD
    Current Clock Speed 3300 Mhz
    Max Clock Speed 3300 Mhz
    Voltage 1.3V
    External Clock 200 Mhz
    Serial Number 178BFBFF00600F12
    CPU ID AMD64 Family 21 Model 1 Stepping 2
    Socket Designation CPU 1
    L1-Cache 288 KB
    L2-Cache 6144 KB
    L3-Cache 8192 KB
    Motherboard
    Model 2AC8
    Manufacturer Gigabyte
    Serial Number
    BIOS Name BIOS Date: 04/05/12 09:50:30 Ver: 04.06.05
    BIOS Vendor AMI
    SMBIOS Version Ang_716
    BIOS Date 4/5/2012
    BIOS Features
    PCI is supported Yes
    Plug and Play is supported Yes
    BIOS is Upgradable (Flash) Yes
    BIOS shadowing is allowed Yes
    Boot from CD is supported Yes
    Selectable Boot is supported Yes
    EDD (Enhanced Disk Drive) Specification is supported Yes
    Int 5h, Print Screen Service is supported Yes
    Int 9h, 8042 Keyboard services are supported Yes
    Int 14h, Serial Services are supported Yes
    Int 17h, printer services are supported Yes
    ACPI supported Yes
    USB Legacy is supported Yes
    Memory Resource
    Used Memory 2.95 GB
    Memory Usage 18%
    Video Adapter
    Name AMD Radeon HD 7450
    Video Processor ATI display adapter (0x677B)
    Manufacturer Advanced Micro Devices, Inc.
    Video Architecture VGA
    DAC Type Internal DAC(400MHz)
    Memory Size 1.00 GB
    Memory Type Unknown
    Video Mode 1440 x 900 x 4294967296 colors
    Current Refresh Rate 75 Hz
    Driver Version 8.941.3.0
    Driver Date 2/10/2012
  2. Banned
    New York, US
    I don't recall TVMW5 ever stating that they had native XVid support for input or output. Are you just editing, or are you trying to re-encode to another format? TVMW5 is not a smart-rendering editor. Basically, it's an encoder.
    http://tmpgenc.pegasys-inc.com/en/product/tvmw5_spec.html
    Oct 2013
    North Carolina
    I finally got it figured out....had to delete the new version of Xvid and install an older version
    I usually convert with TMPGEnc
    from one format to another.
    So I would assume now that the new Xvid will not work with TMPGEnc Video Mastering Works 5
    thanx for your input!
  4. Banned
    New York, US
    I wouldn't know, as I've had little use for Xvid during the past few years, and would never subject a video to multiple lossy re-encodes in the first place. But many people do (I don't know why). It's possible that TMPGenc is really conniving with ffdshow or some other XVid codec source in your system, because TMPGEnc doesn't come with native XVid support any more than it comers with native support for Lagarith or hufffyuv.
