Results 1 to 18 of 18
  1. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    This is a test of the forum post system. This is only a test. Were this a real post, it wouldn't be a test.
  2. DECEASED
    Jun 2009
    Heaven
    testing...
  3. DECEASED
    Jun 2009
    Heaven
    In other words,
    Hmmm, perhaps it depends on the browser you're using ------ ¿ or not ?
    SOme jpgs wont work like Click image for larger version
ID:	20406 but this one worksClick image for larger version
ID:	20405in the editor.
  5. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Problem seems to be triggered if any dimension in the JPEG exceeds 600 pixels.
  6. DECEASED
    Jun 2009
    Heaven
    OK, but why does it happen with JPEGs only?
    Below is a 256-color PNG, re-compressed from the (not-so-)original 256-color PCX source.
  7. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    You're asking the wrong guy!
    I think you're uploading them differently than Baldrick and I. Looks like you're using Upload Files at the bottom rather than the inline Upload Image at the top.
    EDIT: Never knew that "A/A" in the top-right lets you see the code. The tag that brings up the WYSIWYG thumbnail is ATTACH=CONFIG. But now when I hit Save I'm back to the "Attachment text instead of image" problem.
    Regular "Upload Image" that automatically turns into ATTACH.
    Manually edited to ATTACH=CONFIG.
    [Attachment 20434 - Click to enlarge]
  8. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Quote test.
  9. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Manual change to ATTACH=CONFIG in Quick Reply mode.
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    I guess I know why vbulletin has changed to http://ckeditor.com/ in newer vbulletin versions.
    This editor is buggy as hell.
  11. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
ID:	23139Click image for larger version
    ATTACH=CONFIG no longer brings up the WYSIWYG display. It did just a few days ago. At least according to my memory.
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    use the preview post to see how it looks like.
    I will not enable the WYSIWYG editor.
  13. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Yes, I can see how it looks but there is no way to turn an image into a thumbnail now when I want to add a post to a thread like this: https://forum.videohelp.com/threads/360704-2013-my-video-capture-device-comparison-screenshots
  14. I'm a MEGA Super Moderator Baldrick's Avatar
    okey. I'm stupid. I can of course let you choose editor. You find it under the forum settings, https://forum.videohelp.com/profile.php?do=editoptions and choose Enhanced Interface - Full WYSIWYG Editing.
  15. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Thanks! It was on Standard. Looks like I still have to manually change ATTACH to ATTACH=CONFIG to change them to images from text.
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Doesn't it work like before?
  17. I'm a MEGA Super Moderator Baldrick's Avatar
    Buggy as hell...
