  1. Hi guys , I have like 100 clips in MP4 and I'd like to cut from all of them first 30 seconds or so and I know that there are a lot of tools out there but all of them that I've tried are for do it 1 by 1 and what I'd like to do is to do it in "batch mode " to do something like config files that I want and press "enter" . Do you know any tool that can do that? Would be need to recode the videos?
    Thanks for your help
    You can use ffmpeg with a batch file.
    ffmpeg cut example:
    http://stackoverflow.com/questions/15629490/how-to-cut-part-of-mp4-video-using-ffmpeg-...losing-quality
    and then you make a batch file for it
    https://forum.videohelp.com/threads/356314-How-to-batch-convert-multiplex-any-files-with-ffmpeg
    I'm not sure you will find any easier method with a gui/frontend.
  3. Thanks for answer , what I've tried is this :
    for %%a in ("*.mp4") do ffmpeg -i "%%a" -t 21 -acodec copy -vcodec copy "newfiles\%%~na.mp4"
    But result is that I get the first 21 seconds of the video and what I want is to delete that part and get the other part.
    Thanks again!
    Edit: Fixed!
    for %%a in ("*.mp4") do ffmpeg -i "%%a" -ss 20 -acodec copy -vcodec copy "newfiles\%%~na.mp4"
    Great! And thanks for posting your working ffmpeg command.
  5. Originally Posted by Baldrick View Post
    You are welcome (I think you can close this thread) .
