Here is the info of the files i have. They are generally 3 gb files. More than 100 files. This is a broadcast capture, not movie.
So i dont need BEST quality but i have enoughu disk space. I dont want to convert one by one. How can i automatically
convert all of these files to an other format?
General
Complete name : D:\biten\00002013-02-23.avi
Format : AVI
Commercial name : DVCPRO
Format profile : OpenDML
File size : 3.17 GiB
Duration : 14mn 58s
Overall bit rate mode : Constant
Overall bit rate : 30.3 Mbps
Writing application : Lavf55.7.100
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Duration : 14mn 58s
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:00:00
Time code source : Subcode time code
Stream size : 3.01 GiB (95%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 14mn 58s
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 164 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 21 ms (0.53 video frame)
Each file is 3gb and there are nearly 100 *36 gb. I dont want this way.
all of them totaly 3-5 gb is enough. They are broadcast movies from TV. -
You mean all 100 files reduced to 3-5 G in total? From about 3600 G?
Apparently you really "don't need BEST quality".
I don't know if you need them to work on some device with limited codec support, but otherwise do as suggested and forget divx and wmv. h.264 is the best codec but the settings are more complex. And do read jagabo's link. -
He means he has 100 files of 3 GB size each. The 36 is clearly a typo.
The files have massive bit rates for SD video (28800 Kbps video, PCM audio) so they should actually compress quite nicely to DivX.
I'd advise going with DivX over WMV as DivX has better support on various devices. Come on guys, both DivX and WMV are both quite capable of providing excellent quality given the right encoding parameters. Geez, you do nobody any favors by acting like this is impossible when it is not. For example, he could try 4000 Kbps video and 256 CBR MP3 audio. At 4000 Kbps, the video should be equivalent to very high bit rate DVD video. -
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 22:40 -
Unable to convert some WMV files to Ipod Touch format - Why?
By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 05:22 -
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 13:32 -
I want to convert WMV files, but only the audio, how ?
By joboxers in forum Video ConversionReplies: 4Last Post: 14th Oct 2008, 08:13 -
how to convert bbc iplayer wmv files to mp4
By BeachNut in forum Video ConversionReplies: 1Last Post: 10th Jun 2008, 17:01
