Hello!
Last day I used this software to fix a mpeg2 file, but it has compressed the video into an orrible quality.
What am I done wrong?
edit: often, if you can, give me info about the program... the positive aspects and the negative ones
Results 1 to 17 of 17
To be able to help, you will have to give more details like what fixing did you try to do, what size was the original file, what presents did you use for output file.
And provide mediainfo (text summary) of a.) the original file, and b.) the TMPG output file.
It's possible you just selected too low a bitrate.
https://forum.videohelp.com/threads/166963-TMPGEnc-bitrate-setting -
I checked the options: if I start from a d2v file I have to insert manually all the options (even bitrate and aspect ratio)
How I can load the default options of the mpeg2 file taken from the dvd? -
What fixes did you make? It's not at all clear why you're doing any of this.
DVD is all ok. But when I extract the .mpeg (or rename) it is corrupted (audio disappears near the end of the video, and progress bar doesn't works).
So I demuxed video with DGINDEX (ac3 for audio and d2v for the video) and opened with TMPG
VIDEO SOURCE: file d2v
AUDIO SOURCE: ac3
But if I not touch the options the file comes out with a low bitrate, so I have to insert manually aspect ratio and various things.
My question is: there's a method, with this software, that I can use to load the default details of the mpeg2 file?
A normal multiplex, without recodes or size change. The same as the original, but fixed. -
d2v is not the mpeg source, it is a DGindex project file. I don't think you can remux the assets this way,
it will end up re-encoded.
You should use the DGindex option "save project and demux video".
Then use the resultant m2v/ac3 file and Tmpg tools to do a simple remux. -
Also try TMPGENC Mpeg Smart Renderer 4 https://www.videohelp.com/tools/TMPGEnc-MPEG-Editor
(like videoredo paid) -
a D2V isn't a video file, as you've already been told:
Do we write these things just to see our name on the page? Is it in one ear and out the other with you? Do you learn anything ever? Did you already try Imago to remux your M2V and AC3? If not, why not? Why are you reencoding with TMPGEnc when all you want to do is mux? -
This is another problem, mate!
For a couple of mpeg I using your suggestions about Imago, and everything is all right. -
Problem solved! I am an idiot, because instead of going on ''mpeg tools'' I used the main screen (the basic one, at the beginning)
i like your avower.I am an idiot,
may be me too! but, did i say that? "NO"
please do not say that again bcoz here nobody says that!
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36
