    Apr 2013
    I used tsmuxer, the disk will play on the computer but not the ps3. Here is its info
    General
    Complete name : M:\Video Edits\The Hobbit
    Format : Blu-ray movie
    Duration : 2h 49mn
    Overall bit rate : 0 bps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : 27
    Duration : 2h 49mn
    Bit rate mode : Variable
    Bit rate : 5 190 Kbps
    Maximum bit rate : 40.0 Mbps
    Width : 1 280 pixels
    Height : 536 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Stream size : 6.42 GiB (75%)
    Writing library : x264 core 129 r2245 bc13772
    Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=18 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5190 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.0
    Language : English
    Source : 00000.m2ts
    Audio
    Menu ID : 1 (0x1)
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : 130
    Duration : 2h 49mn
    Bit rate mode : Constant
    Bit rate : 1 509 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.79 GiB (21%)
    Language : English / English
    Source : 00000.m2ts
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 2h 49mn
    Source : 00000.m2ts
    Menu
    00:00:00.000 : Chapter 1
    00:08:51.530 : Chapter 2
    00:12:58.903 : Chapter 3
    00:16:34.618 : Chapter 4
    00:20:50.666 : Chapter 5
    00:25:09.007 : Chapter 6
    00:33:14.409 : Chapter 7
    00:38:26.804 : Chapter 8
    00:43:40.367 : Chapter 9
    00:50:12.300 : Chapter 10
    00:55:16.938 : Chapter 11
    00:57:04.838 : Chapter 12
    01:07:51.942 : Chapter 13
    01:12:11.368 : Chapter 14
    01:16:03.559 : Chapter 15
    01:22:06.463 : Chapter 16
    01:28:49.991 : Chapter 17
    01:32:03.518 : Chapter 18
    01:33:42.533 : Chapter 19
    01:40:29.606 : Chapter 20
    01:43:06.847 : Chapter 21
    01:49:12.963 : Chapter 22
    01:54:04.587 : Chapter 23
    01:56:58.094 : Chapter 24
    02:10:27.945 : Chapter 25
    02:12:26.021 : Chapter 26
    02:13:37.718 : Chapter 27
    02:17:59.437 : Chapter 28
    02:20:09.359 : Chapter 29
    02:22:59.111 : Chapter 30
    02:33:58.562 : Chapter 31
    02:39:27.558 : Chapter 32
    The file was an MKV
