I am authoring AVC video files to Blu-ray (BD-R and BD-RE) using tmMuxeR 1.10.6.
When I play the disk on the PS3 I am getting a black image, and it looks like its spiking every 10 - 15 seconds. The disk is video only, so no audio is present.
Here is the Mediainfo on the AVC file:
The AVC file was transcoded using x264 within ffmbc (ffmpeg).Code:General Complete name : /mnt/externalHDD/bluraytest/output/fromx264/Marksmen_Alt_Full_NoAuduio.h264 Format : AVC Format/Info : Advanced Video Codec File size : 4.62 GiB Overall bit rate mode : Variable Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Bit rate mode : Variable Bit rate : 30.0 Mbps Maximum bit rate : 40.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Writing library : x264 core 118 Encoding settings : cabac=1 / ref=6 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=30 / keyint_min=3 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=abr / mbtree=1 / bitrate=30000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Here is the ffmbc command:
The source files vary from DNxHD MXF, to QT files, the problem occurs on both.Code:ffmbc -i $filein -flags +ilme+ildct -tff -an -vcodec libx264 -level 4.1 -preset veryslow -tune film -x264opts bluray-compat=1:weightp=0:bframes=3:nal-hrd=vbr:vbv-maxrate=40000:vbv-bufsize=30000:keyint=30:b-pyramid=strict:slices=4:tff=1:aud=1:colorprim=bt709:transfer=bt709:colormatrix=bt709:sar=1/1 -b 30M -bt 30M -threads 0 $fileout
The AVC file plays fine within a media player on the computer.
I don't know know if its the Muxing or the transcoding that's the problem.
Please help me with my topic about tsmuxer and subtitles.
https://forum.videohelp.com/threads/355380-TSmuxer-problem-with-m2ts-Subtitle
Encoding SD video with H.264 to be 100% Blu-ray compliant.
By PuzZLeR in forum User guidesReplies: 14Last Post: 19th Oct 2015, 18:12 -
Blu-ray + DTS-HD authoring with tsMuxeR
By Zerrax in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2011, 19:30 -
Problems authoring Blu-Ray from HD Camcorder files
By Arnold_Layne in forum Authoring (Blu-ray)Replies: 3Last Post: 30th Jun 2011, 12:35 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
Blu-ray encode to h.264 - Audio Problems
By sangood in forum Blu-ray RippingReplies: 5Last Post: 25th Apr 2008, 07:32
