Hello!
Read other threads and it was not clear to me
how can I add a logo ( image png or jpg) to encode in MeGUI using scritp below? sorry but you need it
"DirectShowSource (" F: \ Paste \ file.ts ")
Load_Stdcall_Plugin ("C: \ Users \ Maicon \ Desktop \ MeGUI \ tools \ yadif \ yadif.dll")
Yadif (order = 1)
LanczosResize (1280.720) # Lanczos (Sharp)
Tweak (0,1,0,1) "
input file> ts
output file> mkv
I can do conversions without problems, but I need the file skirt with a logo in the bottom right corner
sorry for my english.
thank you.
Results 1 to 15 of 15
the logo should be the beginning to the end of the video, without interruptions
logo = ImageSource("C:\Users\Maicon\Documents\Nova pasta\rotatetrans.png).ConvertoRGB32
mask_clip = Mask(logo, logo.GreyScale.Levels(0, 1, 75, 0, 255))
Overlay(logo, mask=ShowAlpha(mask_clip), y=5, x=990, mode="blend", opacity=100)
no works -
i dont understand nothigh, i am noob. I'm having trouble
how to adapt it to my case?Last edited by muxado; 17th Apr 2013 at 22:15.
I use this for png with alpha channel, it is taken from this forum also, cannot find particular thread now, you use your script that works for video and you just add:
Code:clip=last logo=ImageSource("E:\.....path....\transparent_logo.png", pixel_type="RGB32") Overlay(clip,logo,mask=logo.ShowAlpha()) -
what I say is adjust the logo for the post that I want on video
that your script, the logo was on the upper left, but I want to stay fit in the right lower -
_Al_ is saying make the logo image the same dimensions as the video, position the logo in the image editor (eg. photoshop) ,save with alpha channel
or you can use
Overlay(clip,logo,x=600, y=300 , mask=logo.ShowAlpha())
Adjust x, and y value to position it exactly where you want -
Change overlay line to
x and y are measured in pixels from top left corner of the video to the top left corner of the logo. x is horizontal, y is vertical. Replace ? with your values.Code:Overlay(clip,logo,mask=logo.ShowAlpha(),x=?,y=?)
Start with x=0, and y= difference in height between logo and video.
Gradually increase x and reduce y till you have positioned the logo to your liking. -
ow very thanks.
Al and poison and mgh.
got what I wanted...
forgive my ignorance on the subject -
to position the logo in the script as you say, is perhaps faster, less calculations, hunting all those alpha channel pixels all over picture ... have to try it when there is a chance ...
Need help to use megui
By Kaavalan in forum DVD RippingReplies: 2Last Post: 2nd Dec 2012, 06:38 -
MEGUI R!pp!n !!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2010, 11:29 -
MeGUI
By anirban in forum Video ConversionReplies: 4Last Post: 4th Dec 2008, 20:28 -
help using megui
By 3289275 in forum Video ConversionReplies: 2Last Post: 12th Oct 2008, 09:26 -
Changes in MeGUI
By Dschultz in forum Blu-ray RippingReplies: 3Last Post: 24th Sep 2008, 16:55
