Page 3 of 23
FirstFirst 1 2 3 4 5 13 ... LastLast
Results 61 to 90 of 673
  1. Spoke too soon. It crashes habitually if I seek quickly.
  2. Daum PotPlayer 1.5.39036 - x86/x64 Stable
    • Added the ability to jump to previous/next keyframes (Ctrl+Shift+Left/Right)
    • Added the ability to shutdown/sleep the PC in a specific time
    • Fixed a problem where the function storing bookmarks to PBF file does not work
    • Fixed a problem that color came out strangely when game capture function is used in certain games
    • Fixed playback problem of certain WMA files
    • Fixed an issue that the program does not pass to the next item after playing certain MKV files
    I still don't get a .PBF file...
    Found it. It's next to the films...
  3. something wrong, all my history recent files disappear in "album/favorites" . i unchecked "remove noexited files". has PotPlayer a bug or "auto delete a history", "auto limit a history", "auto delete after time a history"?
  4. I guess it's not a potplayer issue. or just update to the latest version to confirm the problem.
    Jun 2010
    New Zealand
    If I upgrade to a new version Do I still keep any settings that I have changed ?
  6. Originally Posted by Digmen1 View Post
    I'm not sure. With bet upgrades you do, for sure. Someone claimed a while ago that the installer resets the settings, so maybe with the full version removes the settings.
    Anyway to be sure, set potp to store the settings in an .ini file, and back it up somewhere.
    Jun 2010
    New Zealand
    I had just installed the latest version from here and, yes I lost all of my settings.
    So next time I will try what you suggest.
  8. Anyone knows how to use avisynth scripts? I always get script error.
    I'm particularly interested in this one: http://forum.doom9.org/showthread.php?t=134078
  9. What kind of error did you get?
    Before starting, try to use the one included in the player. I've tried and it worked well with built-in decoders.
  10. Originally Posted by sheppaul View Post
    I've tried multiple built-in scripts but they didn't work. Except for the color bar. But that only shows a color bar...
    I always get an error starting with "there is no function named" and than a name like 'Deblock'.
  11. Additional filters for avisynth should be installed manually.
    For example, truemotions requires InterFrame library somewhat similar to SVP.
    As it uses SetMTmode, you may need multi-thread version of avisynth.
    http://forum.doom9.org/showthread.php?t=148782
  12. Originally Posted by sheppaul View Post
    I'm not sure what you mean. Where do I get the filters?
  13. Originally Posted by mzso View Post
    You search: https://www.google.com/#q=avisynth+deblock
  14. I see. I thought I had to copy from avisynth or there was a library or something.
  15. Okay, now I get it. I thought potplayer supports avisynth scripts and not just uses avisynth.
    @jagabo
    Now I get invalid argument error for 'Deblock' so I guess that's a step forward.
  16. Originally Posted by mzso View Post
    Post your script.
  17. Originally Posted by jagabo View Post
    Post your script.
    The one I mentioned earlier:
    Deblock() dfttest() FastLineDarken() deen("a3d",4,8,9) Spline36Resize(last.width*2,last.height*2) AddBorders(4, 0, 4, 0) aWarpSharp(depth=12,blurlevel=4,thresh=0.2,cm=1) FastLineDarken() aWarpSharp(depth=6,blurlevel=4,thresh=0.7,cm=1) Crop(4,0,-4,0) FastLineDarken() DeHalo_Alpha() fft3dgpu(bt=3,sigma=8,sharpen=1.3) Spline36Resize(last.width/2,last.height/2)
    Wow the Code tag works geniously... Or the forum engine otherwise destroys the line breaks.
  18. Originally Posted by mzso View Post
    Post your script.
    New attempt:
    Deblock()
    dfttest()
    FastLineDarken()
    deen("a3d",4,8,9)
    FastLineDarken()
    Crop(4,0,-4,0)
    FastLineDarken()
    DeHalo_Alpha()
  19. You need to add a source:
    AviSource("filename.avi")
    Deblock()
  20. I just wonder if this script will work for real-time process.
  21. Originally Posted by jagabo View Post
    Deblock()
    Okay. The others have potplayer_source(), so I guess I need to use that.
    Now I'm stuck at dfttest, because it can't load "libfftw3f-3.dll" even though it's in the same folder.
    God, this is a nightmare. Apparently this one needs the dll int the potplayer directory, others were fine with AviSynth 2.5\plugins\. And one explicitly wanted "AviSynth 2.5\plugins\InterFrame-2.5.0\Dependencies\"
    Just awesome.
  22. dfttest - README.txt: Requires libfftw3f-3.dll to be in the search path.
    https://forum.videohelp.com/threads/335181-Keep-getting-libfftw3f-3-dll-could-not-be-loaded-error
    It should be in the system folder of windows.
    in case of x64 -> c:\Windows\SysWOW64\
    i quit
    FYI, it seems not work with AvisynthMT version
    ps. You need to load the plugin specifically too.
    http://forum.doom9.org/showthread.php?p=1103105#post1103105
  23. After getting files for nearly every friggin line I get a plain black screen after I added fft3dgpu...
    Marvellous...
  24. So without the fft3dgpu() line you don't have a problem? See the requirements for use of fft3dgpu() -- certain nvidia or ati graphics cards.
    http://avisynth.org.ru/docs/english/externalfilters/fft3dgpu.htm
    If you don't have one of those cards use the non GPU fft3dfilter() instead.
    By the way, I doubt you'll be able to get realtime playback with that filter sequence. On my quad core i5 2500K and multithreaded AviSynth I only get around 4 fps with SD material.
  25. Originally Posted by jagabo View Post
    No. It misses it without it.
    I'll try. Thanks.
  26. Gah avysinth is spectacularly horrendous.... Anyway I tried the simpler version of the script. Of course that doesn't work either... Hunted down what it needs, but dies within LimitedSharpenFaster, with some sort of invalid mode error online 102
  27. "Auto close the last file on complete" does not display the current logo screen. I manually close the file to display the logo.
    I'm currently using the latest non beta version and use Potplayer to play DVD and BD movies only.
    This issue goes back quite a few versions.
    Is there some other setting to make this work?
  28. While creating a new skin I've encountered some bugs:
    • Many times PP doesn't obey the WidthLimit & HeightLimit values in MainSkinArea (at least in Direct3D 9 skin overlay mode).
    • User menus aren't displayed if triggered by AltCmdIDs in Direct3D 9 skin overlay mode.
    • If in a paused state clicking 'Next bookmark' can get stuck on the current bookmark (it doesn't affect clicking 'Previous bookmark').
    Perhaps some of these are limitations (?) but the first two issues in particular would be nice to see fixed.
  29. If you get any bugs, you can report it to ahahlive@hanmail.net
