Windows 7 Ultimate 64 Bit build 7600
Ok. This is getting really aggravating. I have the file libfftw3f-3.dll in AVISynth's folder but when I try to load up a script in MeGUI, it tells me it can't load the file.
This is the script I'm trying to use:
MPEG2Source("C:\Users\Nagashi\Desktop\Project X\MPEG Files\27.d2v")
DFTTest()
Tweak (sat=1.2)
Crop(4,0,-2,0,true)
Lanczos4Resize (640,480)
Trim (0,2697)
It says the problem is line 2 (DFTTest) but what the heck is the actual problem? I have the files for DFTTest in the AVISynth folder. I already tried putting libfftw3f-3.dll in the system32 directory.
I am getting the same error. Tried your solution, but still getting the error
"libfftw3f-3.dll is not avisynth plugin"
If you are still online, please suggest another solution.
Thanks.
PS: My script for VirtualDub
Code:SetMemoryMax(512) LoadPlugin("C:\Hybrid\avisynthPlugins\DGDecode.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\mt_masktools-25.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\YadifMod.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\NNEDI3.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\MVTools2.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\GScript.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\Grunt.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\RemoveGrainSSE2.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\aWarpSharp.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\SangNom.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\UnFilter.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\Toon.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\DFTTest.dll") LoadPlugin("C:\Hybrid\avisynthPlugins\libfftw3f-3.dll") Import("C:\Hybrid\avisynthPlugins\SRestore.avsi") Import("C:\Hybrid\avisynthPlugins\QTGMC-3.33.avsi") Import("C:\Hybrid\avisynthPlugins\santiag.avs") Import("C:\Hybrid\avisynthPlugins\AAA.avs") DirectShowSource("E:\Cartoon01.mkv") AwarpSharp2(depth=6) santiag(strh=2,strv=2) AAA() Toon(strength=0.6) DFTTest() LSFMod(strength=50) SmoothLevels(0,1,245,0,255,false)Last edited by ConverterCrazy; 12th Jul 2016 at 11:05.
libfftw3f-3.dll is not an AviSynth plugin and should not be loaded in your script. It's a Windows system plugin. Put a copy in Windows' System32 folder, or when using 32 bit AviSynth under 64 bit Windows put it in the SysWOW64 folder. Windows will automatically load it when needed. Ie, usually:
C:\Windows\System32
C:\Windows\SysWOW64
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 18:55 -
enc_aacplus.dll error while using AutoMKV
By nx01rules in forum DVD RippingReplies: 3Last Post: 15th Oct 2009, 05:24 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
