Hi,
My name is Alex. I am in China and I accidentally left my guitar in an elevator. When I went back it was gone. I know I know, I'm pretty stupid but everyone makes mistakes, right? I have lo-res security videos from each floor of the building I was in, but I can't watch them because they're somehow encrypted or cannot be decompressed for some reason. I am a video newb, but if anyone on here is willing to help, I am attaching a couple of the videos in case one of you can find a way to open them. The files are small. Help would be most appreciated.
Thank you so, so much.
Alex
Results 1 to 9 of 9
Probably same/similar video format as https://forum.videohelp.com/threads/350942-Need-help-viewing-and-converting-cctv-footage
Yep, it worked to change the n264 to xvid.
I used ultraedit. Opened the mpg. Changed the two n264 to xvid.
Sample attached and renamed to .avi. It works in VLC Media Player. -
I got it from the security guards in the building where I'm staying.. My Chinese isn't that good (especially with computer stuff) and I have already bothered them a lot so I was just wondering if there was any way to watch these vids before I go see them again. I'll take a look at this thread you posted.
Alex -
Se my post above. And before you hex edit the files make a backup of it.
Whoa!! I'm very impressed sir. Is this difficult to do? Is the software free/cheap/expensive?
Alex -
No, it's simple. Try a free hex editor like http://download.cnet.com/HxD-Hex-Editor/3000-2352_4-10891068.html
Open the mpg. You should see the N264 at the beginning of the file. Change to xvid. Save as a new .avi. -
Thanks so much again. I will definitely send people to this site!!
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 18:58 -
security cam video help
By nemesis117 in forum Newbie / General discussionsReplies: 2Last Post: 14th Mar 2012, 18:20 -
Security Camera video footage software..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2010, 03:38 -
how to stream video in a security system?
By marada in forum Video Streaming DownloadingReplies: 0Last Post: 29th Dec 2009, 16:28 -
.264 Video footage taken from a security camera
By mike29892 in forum Video ConversionReplies: 4Last Post: 25th Apr 2008, 16:51
