Hello folks,
This is continuation of this thread.
When I convert DVD to XviD using AutoGK, I rip subtitles as well. As I mentioned in the thread before, I prefer to delete the last part of the movie. I wonder in that case, can I still use the same subtitles or I need to edit them. If I need to edit them, how do I do that?
Thanks in advance.
P.S. - If this question needs to go in Subtitle section, please move it there.
You must edit the subtitles manually. With for example subtitle edit.
It's OK to remove the last part of the film (the end credits I assume). The subs will still play even if there are translations in the part you've removed. It's when you remove something from elsewhere in the film that the subs will go out of synch.
Edit: Just read the earlier thread. If there aren't any subs you want after the beginning of the edited part, you won't need to edit the subs. If there is some more dialog after the edited part, then do as Baldrick said.
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 19:04 -
AVI Trim
By drgt in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2010, 05:36 -
.avi trim and save in original file
By AmyM123 in forum Newbie / General discussionsReplies: 4Last Post: 24th Feb 2010, 15:21 -
Help adding subtitles to CHE part one
By viruss3 in forum SubtitleReplies: 2Last Post: 18th Jan 2009, 14:23 -
Cannot make subtitles work with specific avi
By tr_y2k in forum SubtitleReplies: 4Last Post: 4th Dec 2008, 13:24
