Results 1 to 9 of 9
    Mar 2008
    Singapore
    To date, I have tried a lot of different video converters, but none of them can satisfy all the needs that I have. These are as follows :
    - Maximize usage of CPU Cores / CUDA / RAM
    i'm on a i7 OCed, with 16gbs ram and a gtx 660ti. for instance, AVC only uses 30+% CPU and very little ram when batch encoding videos, even when set to max priority. I want my cpu to be fully utilized during conversion - 100%.
    simultaneous conversion of multiple videos AND multi-threaded conversion of SINGLE videos would be perfect!
    - Hassle free drag-and-drop batch encoding
    something like AVC is good. handbrake is good at encoding, but terrible for its batch interface.
    - able to support many formats
    most of the time, i'm recoding stuff to save space - for instance .vob to h264.
    - able to stick to the same aspect ratio and resolution as source (i.e. not upscaling or downscaling) without manual intervention
    SUPER does this, but not AVC. i have to manually type in the source resolution to get it to convert similar to source.
    same goes for directories - i don't want to waste time setting the output directory - i just want it to stick to the source directory.
    am i asking too much for the above features? i don't mind paying for one, but i have not seen one that has all the above features that i need!
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Might try IMTOO video converter. http://www.imtoo.com/video-converter.html Converts most formats, uses ATi/CUDA, can set each file in batch to separate formats of the same, drag and drop, etc. Check it out. I have version 6 but version 7 is the current and I have not tested that one.
Name:	ScreenHunter_358 Dec. 03 01.15.jpg
    Its not free and all tnhose features would be hard to find in a free version I think.
  3. MediaCoder - except from using source directory as output directory.
  4. Member ozok's Avatar
    Oct 2011
    Turkey
    You can do them all with TEncoder (maybe not CUDA stuff).
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    for x264 batch stuff i use vidcoder
    Mar 2008
    Singapore
    thanks guys, seems like imtoo fits the bill for all my requirements right now. will try that and let u guys know.
    btw, is there any simple app that can convert 3D SBS clips to 2D?
  7. Member Cornucopia's Avatar
    If the app you use supports AVISynth scripts just insert:
    leftcrop3D=crop(0,0,-Width/2,0)
    2D=LanczosResize(leftcrop3D, (Width*2),Height)
    Mar 2008
    Singapore
    is there a GUI that can help convert 3d SBS to 2d? sorry cos i'm not familiar with avisynth.
  9. Wow, it not very often you see someone take three years to respond to a post. Well done.
