Results 571 to 585 of 585
read old post on this forum.
is full to thred to this.
like this: https://forum.videohelp.com/threads/403866-Download-from-NPO#post2638556 -
Rte has also changed it's drm policy.
But what info is now needed for either wsk-key or https://getwvkeys.herokuapp.com/ to work?
the pssh is easy to obrain, but the license url seems to be a tad tricky to find in the mpd or in the modulardrmtoken (side note, the license search in dev tools gives up the oplayer, but that's adverts and or facebook, so not relevant.)
essentially, what the hell is the license url -
License url is https://widevine.entitlement.eu.theplatform.com/wv/web/ModularDrm?token but you also need the pid from the request headers goodluck
default license request may be in json format, like this;
with the parameters in the json data body, like this;Code:https://widevine.entitlement.eu.theplatform.com/wv/web/ModularDrm?form=json&schema=1.0&token=ey ...
license request can be altered to raw binary (instead of json), using query string parameters, like this;Code:-H "Content-Type: application/json; charset=UTF-8" --data-binary "{\"getWidevineLicense\":{\"releasePid\":\"SzLfsGit_dRx\",\"widevineChallenge\":\"CAQ=\"}}"
Code:https://widevine.entitlement.eu.theplatform.com/wv/web/ModularDrm/getRawWidevineLicense?schema=1.0&form=json&releasePid=SzLfsGit_dRx&token=ey ...
That's very helpful, thank you. Although I must be having a senior moment in trying to understand what to do with the licence url.
Of the examples above, let's take the third one, would that url be entered into the licence url at getwvkeys as
where XXXXXXXXXXXX is the pid, what follows ey..Code:https://widevine.entitlement.eu.theplatform.com/wv/web/ModularDrm/getRawWidevineLicense?schema=1.0&form=json&releasePid=XXXXXXXXXXXX&token=ey ...
Also, would that URL work in the WSK-Key script? -
the site also needs a variable program Id sent in the headers also in the json
He added a section to accommodate it but there were updates yesterday also for rte it seems which made the cracked android cdm defunct now also. I'm not aware of other cdms that are cracked.
I think https://getwvkeys.herokuapp.com/
Will be dead as of today for many sites
If someone finds one let me know.
Ive looked through these and can get pssh, licence url, mpd headers, pid etc but pywidevine and wvdecrypt are currently out of action from what I can see. I'm not sure how they work yet myself I need to read up on it. -
Hello. Since I'm seeing tech-savvy people being extremely kind here, could someone please help me get this file?
https://www.rte.ie/player/series/the-tommy-tiernan-show/SI0000001918?epguid=IP10010666-09-0001
I would really appreciate if the best quality possible is maintained, but only if it's doable and not too much work! -
N_m3u8DL-RE "https://vod.rte.ie/rte/vod-d/RTE_Prod_-_Prod/153/136/IP10010666-09-0001/M3839519-1735905798260.ism/.mpd" --key 6ad682ab0a3dd72267205d454122d25e:8741ffc090ae1be44d607df8464609f8 -M format=mkv
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
I’d like to download the following video, but I’m not entirely sure what's the best way to do it. If anyone could recommend the best tool, and provide me with the codes, I’d really appreciate your help.
Code:https://www.rte.ie/player/series/the-late-late-show/SI0000001694?epguid=IH10008885-25-0012
Use WidevineProxy2 to get key and the good command to download with N_m3u8DL-RECode:
N_m3u8DL-RE "https://vod.rte.ie/rte/vod-d/RTE_Prod_-_Prod/75/16/IH10008885-25-0012/IH10008885-25-0012-1743203879209.ism/.mpd?filter=systemBitrate%3C%3D7000000&hls_fmp4=true&available=1743203492&expiry=1745791892&ip=83.204.217.225&token1=5ebb79c338babe1f86273259a29804773d677599fbc12273a44d35d8250e7f24" --key 58945ce566f40fcc70a95fd218db142f:c9fa88984eea771cf0fe1bdbfb98bcc1 -M format=mkv
https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping -
How to download flash video RTMP/RTMPE streams using free software
By Baldrick in forum User guidesReplies: 4609Last Post: 6th Mar 2025, 10:32 -
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 14:43 -
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 21:37 -
ripping dvd's with rip-it
By XAPHSNYC in forum MacReplies: 10Last Post: 31st Jan 2010, 21:59 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 10:37
