Page 16 of 20
FirstFirst ... 6 14 15 16 17 18 ... LastLast
Results 451 to 480 of 585
  1. Originally Posted by Buachaill Dana View Post
    Hey guys, I'm not looking to rip video, but audio. Is there a way to download from radio player?
    I have tried a lot of things.
    I ended up using another PC to record the audio of each show I wanted, as it streamed, which is the very last option, and it takes the full length of each show.
    I have so far got 7 shows, but now RTE site won't load properly on the PC anymore, I guess a clearing of history may helpm but want to back it up first.
    I stumbled upon this thread/forum purely by accident. It would be great if it was possible. I am reading over the thread but it is a big one.
    what show are you looking for. i have downloaded clips fom joe duffy, whole show if i want, mp3 files
    Examples
    https://www.rte.ie/radio1/liveline/podcasts/#103070295
    Is that what you mean? i
    i cannot get rte player on firefox or ie have to use chrome. so maybe try another browser
  2. Hi,
    Yep, that is EXACTLY what I mean..
    How did you do it?
    I am trying to get a few of the plays and short stories from different programmes.
    I have tried Chrome, firefox and IE. It was working a week ago, but now they all just show the stripped site and just text. I'm sure there is something blocking it, maybe F-Secure (I don't have much else running on the PC), as I have disabled ublock Origin and that made no difference.
    I am currently using atube catcher to download/record and then editing in audacity.
    Edit - This is how the site looks on my pc in any browser - https://snag.gy/nimcK9.jpg
  3. Originally Posted by Buachaill Dana View Post
    Hi,
    How did you do it?
    How did you do it?
    just googled to site and download as mp3
    have you an adblocker? If so try disabling for rte.Also if you have add ons try running the browser with all add on disabled. I do not have f secure maybe an update there blocked you??. i do not need anything to download them they are just downloaded as mp3
    I had to go to chrome or just get a black screen in firefox on rte player television player
  4. Originally Posted by David Banner View Post
    How did you do it?
    Thanks, but how do you mean googled to site and download as mp3?
    Does that work for the archived programmes?
    Yes, I have uBlock, but i have disabled it for RTE. I'll figure that out, it must be something blocking, but dying to download these
  5. Originally Posted by Buachaill Dana View Post
    How did you do it?
    I mean i just searched in google for rte. google liveline for example. the site opens https://www.rte.ie/radio1/liveline/ see programme archive on the right. click podcasts https://www.rte.ie/radio1/liveline/podcasts/ or https://www.rte.ie/radio1/podcast/podcast_liveline.xml to see the actual mp3 link. Click the link of the item you want and the download is an mp3 file
  6. Originally Posted by David Banner View Post
    Ahh, I get you, thanks.
    unfortunately most of the shows I am looking for don't have podcast links. They do have archived shows though, but have to listen to the full thing.
  7. Originally Posted by Buachaill Dana View Post
    if you can download it as mp3 you could edit it with audacity. i have often done that with interviews
  8. Originally Posted by David Banner View Post
    I can only record it. Can't download unfortunately, or figure a way to do it. Some of the shows are almost three hours, so as you can guess, recording is a pita.
    I have been able to access the site properly in the past, so if it comes to it, I would wipe the PC and reinstall windows/linux (I know, it won't be needed, but I'd be willing to do it).
    I've just not been able to download a direct link, I would/will have queued them all and left the PC on if and when I figure out how.
    In the meantime, looks like recording is the only way to go for now. I'm using atube catcher.
  9. Originally Posted by Buachaill Dana View Post
    post a link to one you cannot down load
  10. Originally Posted by David Banner View Post
    https://www.rte.ie/radio1/late-date/programmes/2019/0219/1031625-late-date-tuesday-19-...7786#103047786
    I can't post an actual link, because it appears like this
    https://www.rte.ie/radio/radioplayer/rteradiowebpage.html#!rii=9:11000831
    of course it works after I said that.
    Either of those links woul be an example of the audio I would love to rip.
  11. Deceased
    Dec 2007
    You can use hds or hls with streamlink.
    https://feeds.rasset.ie/rteavgen/getplaylist/?format=json&id=11000831
    streamlink "hds://http://cdn.rasset.ie/hds-vod/audio/2019/0219/20190219_rteradio1-latedate_cl11000831_11005160_261_/manifest.f4m" best -o "20190219_rteradio1-latedate_cl11000831_11005160_261_.flv"
  12. Originally Posted by blimey View Post
    it does work. how did you get the links? they do not show in network for me. Maybe because the player is seperate box?
  13. Deceased
    Dec 2007
    The "feeds" url shows up in network for me.
  14. Originally Posted by blimey View Post
    ok didn't show for me
  15. I'm going to try that now. Fingers crossed
  16. Is that streamtransport?
    I've looked at software, loads of it. That rings a bell, I think I used it to download from Brightcove about 5 years ago.
    I downloaded your link, but nothing appears as new. (Not a good sign). - But don't mind that.
    Streamtransport appears in my programs along with loads of others I haven't uninstalled but I recocognise that name. I am almost 100% that is the one I was looking for. Thank you, even if it doesn't work.
    That has to be it. Hopefully.
  17. Deceased
    Dec 2007
    streamlink <<<---- (not whatever you've mentioned).
    The forum software here links to the forum page for the program.
    I've already verified that it works with your link, so it doesn't not work.
  18. Originally Posted by Buachaill Dana View Post
    Did you try streamlink ?
  19. Originally Posted by David Banner View Post
    conversion of the ismv file to mp4 with ffmpeg takes a very long time. 2.2 GB file took about 7 hours??. Am i doing something wrong?
    It's not necessary to re-encode the file (unless you have a specific reason).
    Just swap the container from ismv to mp4. It takes about 30s and preserves the original stream quality.
    ffmpeg -i FILENAME.ismv -codec copy -f mp4 -y FILENAME.mp4
  20. Originally Posted by daigo99 View Post
    Does ffmpeg -i SOURCEFILENAME.ismv FINALFILENAME.mp4 reencode it?
    ffmpeg -i FILENAME.ismv -codec copy -f mp4 -y FILENAME.mp4 works fine and quickly
  21. Originally Posted by David Banner View Post
    Yeah, it does (I don't know the specs), hence the lengthy process.
    -codec copy just repackages the stream in a different container, so it's fast and lossless.
  22. Originally Posted by daigo99 View Post
    Didn't know that. Thanks
  23. Lads would someone be able to explain to me how to download this radio programme please?
    https://www.rte.ie/radio/radioplayer/rteradiowebpage.html?rii=b1_11011742_1154_17-03-2...2D03%2D2019%5F
    I've managed to get the rtmpe url from
    https://feeds.rasset.ie/rteavgen/playlist/?type=radio&itemid=11011742
    which I observed in the network viewer as the stream loaded.
    I've tried using youtube-dl, ffmpeg, streamlink, and rtmpdump but just cant seem to get it working. Running linux by the way.
    Any info would be much appreciated as I'd like to be able to download this programme as well as another one.
    Thanks!
  24. jakmar
    If You want to use only rtmpe use TubeDigger
    Otherwise, use IDM
  25. Deceased
    Dec 2007
    The method described here, using streamlink with hds or hls, can also be used:
    streamlink "hds://http://cdn.rasset.ie/hds-vod/audio/2019/0317/20190317_rte2fm-thelatenightsessions-thelatenig_cl11011742_11014162_261_/manifest.f4m" best -o "20190317_rte2fm-thelatenightsessions-thelatenig_cl11011742_11014162_261_.flv"
  26. https://feeds.rasset.ie/rteavgen/playlist/?type=radio&itemid=11011742 -> https://feeds.rasset.ie/rteavgen/getplaylist/?format=json&id=11011742
  27. Deceased
    Dec 2007
    itemid= -> id=
    is better too.
  28. You all are absolute legends. I couldn't figure out how to go from the rtmpe url to the hds url.
    Worked perfectly. Thank you!
  29. Originally Posted by tommycahir View Post
    I am currently trying to download bachelors walk for the Mrs and have found a way to get the files but it's a real pain in the arse manual way, maybe someone here has an idea on automating it.
    1) Go to the series you want to watch and
    2) In firefox press f12 to open the developer console
    3) Go to the Network tab in the developer window
    4) select the episode and then press play
    5) watch the console and select one of the lines when your episode is playing, on the RHS you will see request URL eg https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/69/348/IP9706/M3646081-1541685509261.ism/da...iry=1603350000
    6) edit this URL back to the 1st IPXXXX folder eg https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/69/348/IP9706/
    7) put this in the browser and select the largest file there and it will download a file in .ismv format eg https://vod.rte.ie/rte/vod/RTE_Prod_-_Prod/69/348/IP9706/M3646081-15416769273112496_dc...f85bf7672.ismv
    8) this can be played in VLC or mp4 format can be extracted from it (google it eg ffmpeg - https://ffmpeg.org/ffmpeg-formats.html#mov_002c-mp4_002c-ismv)
    hope this helps
    This method no longer works (HTTP Error 415)
