Results 1 to 18 of 18
  1. Hi, I already posted a thread about my problem here it is:
    https://forum.videohelp.com/threads/349708-Cann-t-burn-mpg-into-vcd-due-to-encoding-problem!
    Now, after trying avi2dvd, after it does transcoding process,
    the encoder window opens and says : Could not decompress frame 0 (c:\source.avs,line 1)
    after searching over the net I found that it might be related to non-packed bitstream
    it is noteworthy that the file has been modified in windows movie maker, does this have something with packed and non-packed bistreams?
    I used MPEG4Modifier hoping it will pack it but I get this err msg : this is not a valid mpeg-4 video start code not begining of the frame
    Please, any explanation or reference or help will be appreciated.
    If you refer to the first thread I put you will know the start of the problem and when I used vcd burning program it also mention that it is related to encoding problem, I just need to burn it to vcd in any way either by recoding first or any other solution. Thanks a lot in advance
  2. Basically, packed bitstream was invented as a workaround for Windows' Video For Windows (VFW) library. VFW is based on a "one frame in, one frame out" paradigm. It reads one frame worth of compressed video from the file, decompresses it, then hands it to the editor. But this paradigm breaks down with codecs that use bi-directional prediction and out-of-order decoding. With bi-directional prediction a frame may need to reference a future frame in order to be fully reconstructed. So the encoder packs the bi-directional frames along with the future frame into what looks like one frame to VFW. Then adds enough "null" frames (place holders for the packed frames) to the compressed stream to fill out the frame count. Internally the decoder decompresses the future frame and the bi-directional frames and stores them in memory until the program reads the null frames.
    http://itsjustonesandzeros.blogspot.com/2007/01/what-is-packed-bitstream.html
    I'm not sure what your problem with WMM is. Are you sure it output a Divx/Xvid AVI?
  3. Banned
    Freedonia
    Packed bitsteam is NEVER necessary. NEVER. Whatever your problem is, I do not think this is it.
    Just use Xvid4PSP on your file to convert it to Xvid and see if that gives you better results.
    Feb 2004
    Australia
    Use mediainfo to determine codecs in play first.
    Mpeg4modifier will show the warning for div3.
    Moviemaker supports dv avi output ... which would be preferred over avi > wmv > other (far too much quality degradation)
    From here a solution may be found.
  5. Originally Posted by jman98 View Post
    It's necessary if you want frame accurate editing in a VFW editor.
  6. Originally Posted by Bjs View Post
    I suspect this is what the OP used. Mpeg4Modifier gives the "not a valid mpeg-4 video..." when opening an DV AVI file. Though that doesn't explain the problem with AVI2DVD.
    Thanks a lot for the explanation, highly appreciate it.
    Regarding WMM, I really don't know if it outputs a divx/xvid AVI, I think it is not coz when I run it in dvd player it says Data Error (divx)
    How can I know if it is not divx avi and what is more important, how can I solve it if it is not divx avi, I am totally newbie this field,
    Many many thanks
  8. Originally Posted by jman98 View Post
    Thanks a lot,so if i convert it to xvid will it be like divx?
  9. Banned
    Freedonia
    MARIGOLD - I told you what to do in my post. But if you would prefer to waste days on your problem and continue to get nowhere, that's OK with me.
  10. Originally Posted by Bjs View Post
    I don't really understand, does 'dv' mean divx? told you totallly newbie
    Anyway, I'll go and search about mediainfo to get more information , thanks a lot
  11. DV as in DV camcorder, DV codec.
  12. Originally Posted by jman98 View Post
    I don't want to waste days definitly
    I just don't understand is divx the same as xvid, by the way, once I read your post I immadiately downloaded and it is converting now one of the files but it takes lots of time, didn't finish converting yet
  13. YES YES YES YES IT WORKED!
    thanks a looooooooooooooooooooooot jman
    I used xvid4PSP , and the converted file worked immediately in the DVD player without the headache of converting it into VCD just like any normal avi, many many many thanks I was about to give up and ignore this file but finally
  14. Originally Posted by MARIGOLD View Post
    Divx and Xvid are two implementations of the MPEG 4 Part 2 spec. Divx is a commercial produect, Xvid a free open source product. For the most part, players that can play one can play the other.
  15. Originally Posted by jagabo View Post
    Uha, I understand now
  16. Originally Posted by jman98 View Post
    I though that the converted file worked, but it seems it worked only for 5 seconds maybe and then it shows Data Error (divx) again,
    I don't know where is the problem but I believe that this program will solve my problem coz it at least managed to run the beginning of the video but maybe I know the steps of using the program
    what I did is:
    1-open the file
    2-video encoding is set at xvid HQ Ultra
    Then I go to encode but it shows me a box saying:
    The application "xvid_encraw.exe" has made an attempt to load ffdshow
    this dialog is shown because this application is not l isted in the ffdshow whitelist or blacklist
    your choice will be applied to both audio and video if both are used
    then it gives me options:
    *don't use ffdshow (just this once)
    don't use ffdshow (always)
    the first one is the selected one by default and then it starts encoding
    by the way, when I try to burn it to vcd it gives me this warning:
    the following properties are not according to the VideoCD standard:
    witdh or height
    video bit rate
    encoding of the video stream
    encoding of the audio stream
    audio bit rate
    general encoding
    the fie is not video CD-compatible
    the video will not work as expected
    please re-encode the video file
    can someone please tell me what is wrong? and how to fix it?
  17. AVI files are not compatible with VCD. VCD is MPEG 1 video at 352x240 29.97 fps (NTSC) or 352x288 25 fps PAL. You need to use an MPEG 1 encoder, not an Xvid encoder if you want to make a VCD. If your player plays Xvid/Divx AVI files you don't make a VCD, you just burn your AVI files to CDs as data files.
    If you really need to make VCDs try using the free version of TMPGEnc.
  18. jegabo, it didn't try to convert it from avi to vcd directly. I used Any Video Converter to convert avi to mpeg, then used ashampoo burning studio to convert it to vcd, it but no vain. My player plays divx files, and I always just burn avi files but this times it does not work, actually they are 34 files, all have been edited in Windows movie maker and all have the same problem, that's why I though about converting it to VCD
    Anyway, I managed to solve the problem and I really believe that the problem is with Windows Movie Maker, what I did to solve the problem is:
    Went back to the Windows movie maker and opened the project of the movie, then saved it as DV AVI, wmm only saves as wmv or DV AVI but the file is too large more than 4 GB
    Then, I used total video converter to convert it from the big sized avi to another small sized avi file
    The final converted file worked finally on the DVD player,
    Thanks for everyone who tried to help me
