Hi,
I'll tell the history of my file maybe it will help you pinpoint the problem.
I had an AVI file, I edited the file in Windows Movie Maker, then saved it as wmv coz I don't not save it as avi, wmv is the only choice available in my version of movie maker.
This wmv, I converted it to avi using Total Video Converter, hoping it will work in my Sony DVD player coz my dvd palyer does not run wmv, it works fine on the laptop, but when I run it in Sony DVD player it says DataError(divx) ==> I searched over the net and found that this is problem in sony I think it happens to files that has been edited - not sure but it generaly runs original avi but not this one.
Now, I want to run the movie in any possiple way in my DVD player
so, I though about making VCD, I used many programs that were supposed to have this VCD option but the only one that had it was
Ashampoo Burning Studio 6
However, when I try to make vcd it says
the following properties are not according to the VideoCD standard:
encoding of the video stream
encoding of the audio stream
general encoding
the fie is not video CD-compatible
the video will not work as expected
please re-encode the video file
Please, can someone tell how to fix this problem?
Either to guide me how to re-encode the video file- I am a total newbie in re-encoding I don't even understand what it means
or to tell me if there is any other way I can run avi file in my DVD player. Please, any help will be highly appreciated.
usually quiet
Thanks a lot, I'll try it and see what happens and thanks million -
https://www.videohelp.com/tools/TMPGEnc
Select Video CD in project wizard, and convert to mpg.
Use a burner which will 'author' the vcd with mpg files provided by you.
I have made a number of vcds with VCD compatible mpgs using TMPGEnc. VCD processing is free with TMPGEnc.
The burner I used at that time was Nero, which given the mpgs, 'authored' the VCD and burnt it. All of them were recognised as VCDs by VCD and DVD players.
Some of the Ulead software could also do it. (conversion to VCD compatible mpgs, author the VCD and burn it)
You can try to use Ashampoo for burning the TMPGEnc converted files. If Ashampoo still says mpgs are not compatible, then Ashampoo is not the correct software for VCDs, regardless of what they claim. TMPGEnc produces 100% VCD compatible files if you use the Video CD profile for encoding.
Ethernet port problem due to new power supply??
By jeanpave in forum ComputerReplies: 11Last Post: 25th Oct 2011, 22:45 -
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 17:04 -
Burn Errors due to MPGV ?
By mrlewp in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2010, 20:54 -
Cannot burn an mpg on a DVD
By costaseco in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2009, 04:15 -
PC Notebook Computer Batteries Recalled Due to Fire and Burn Hazard
By MJA in forum ComputerReplies: 0Last Post: 31st Oct 2008, 16:09
