Results 1 to 10 of 10
  1. Me english no good . This is me first question here. We record security camera. Me want to cut 24 hr long avi video into 24x1hr - 24 different videos. How can? me surfed this forum for while, could not serched the answer.
    Bagh Bahadur
  2. Member bat999's Avatar
    Feb 2008
    Originally Posted by BaaGGHo View Post
    ... want to cut 24 hr long avi video into 24x1hr - 24 different videos.
    Hi
    This can probably be done using mkvmerge-GUI.
    Though the result will mkv files, not avi.
    Automatic splitting
    Enable splitting ...after this duration
    Look here ----> http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#global_split
  3. got 5.7.0, tried after timecode 01:00:00 and got only one file from 01:00hr~24:00hr. me need 24 files.
    last three digit of new file is mkv, but me need avi.
    how can get mkv back to avi?
  4. ...after this duration 01:00:00 worked. thank you.
  5. long avi file play in media player and mkv says format not supported - do not play in media player.
    Cannot play back the file. The format is not supported. (Error=80040265)
  6. There's a guide to splitting AVIs here: https://forum.videohelp.com/threads/249731-Tutorial-Using-VirtualDub-Mod-to-Split-or-Sa...of-an-avi-File
    If you use the slider to navigate through the video, do so while holding down the Shift key. VirtualDubMod can only split video using a certain type of frame as the split point (key frames). That's normal for any program unless you re-encode some of the video. Holding down the shift key while using the slider will make sure you always land on one of those key frames.
  7. Member Cornucopia's Avatar
    I'm pretty sure AVIMux-Gui can remux from AVI to MKV...
    Dec 2005
    Canada
    AviMux-GUI allows you to set the split manually on AVI.
    You would have to plug in all 24 values though before saving the output.
  9. AVIMux-Gui worked, mkv back to avi played good.
    me thank you everyone.
  10. Not that it matters, VirtualDubMod, AVIMux-GUI..... they'll both work..... but for the record if you've got lots of AVI splitting to do VirtualDubMod can save each job to a queue rather than run it straight away, so you can open an AVI, set the start and end points, save it as a new AVI (making sure the option to add the job to the queue is selected before saving it) setup your next split points, save the AVI again.... and so on. You can also open a new AVI and set up splits, saving each to the job queue again.
    Once you're finished you can open the job queue and get VirtualDubMod to start running them and walk away. If there's a lot of splitting to do it saves having to sit in front of the PC waiting for VirtualDubMod to finish saving each time. The same applies to anything you ask VirtualDubMod to do whether it be simple file splitting or editing and re-encoding.
