I'm using the latest x86 vdub on Windows 7 x64.
If I want vdub to recognize the codec do I need to install both x86 and x64? or do I install the x64 version because I'm using a x64 OS? or do I install the x86 version because the vdub I'm using is x86? I'm a bit confused here. I hope someone can explain.
The further away I get from the things that I care about...
the less I care about how much further away I get... -
The 32 bit and 64 bit systems are completely separate. 32 bit programs need 32 bit lame. 64 bit programs need 64 bit lame. So if you're only running 32 bit VirtualDub you only need 32 bit lame. 32 bit VirtualDub cannot use, or even see, 64 bit lame.
Sorry I made a mistake. LAME ACM only comes in 32-bit. What I meant was should I install it in both 32-bit directory (system32) and 64-bit directory since there are directions on how to install the acm on 64-bit systems.
This probably would have helped:
https://forum.videohelp.com/threads/271712-Lame-MP3-Encoder-on-Vista-x64#1723154 -
Yes I read that thread prior to installing. The LAME ACM I downloaded also contained a file specifying how to install on x64 systems, but there was no thread I could find here or Google that specifically stated if I needed to install only in the syswow64 folder or both folders.
Cannot install lame mp3 on vista x64
By jarko in forum AudioReplies: 14Last Post: 28th Apr 2010, 04:12 -
ms visual c++ redistributable x64 & x86 2005 or 2008
By runLoganrun in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2008, 11:20 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 09:16 -
Bluetooth Keyboards problem with Vista x86 and x64
By ofbarea in forum ComputerReplies: 2Last Post: 19th Aug 2007, 21:52
