Hi
I'm editing an MPEG2 (from a DVD) in TMPGENC Mastering Works 5 and about every other cut I make, I've been hearing a loud pop/clicking noise. They're at the end of all my cuts.
I can get around this using Sony Vegas and the crossfade transition...only thing is I lose quality in Vegas and the de-interlace method in TMPEG is second to none. Never mind the fact the hard cuts in TMPGENC look very professional.
Any ideas?
There is a description on the problem and remedy here.
However, it is not for TMPG Master Works. I don't use it, so I cannot advise.
https://forum.videohelp.com/threads/345249-Popping-speakers
Click on the link for the Audacity forum in the above link for an in-depth explanation. -
Vegas pro smart renders mpeg2, if you set it up properly so there is no quality loss with simple cuts (only the few frames around a GOP cutsite if you are not cutting on keyframes). Only filtered sections, overlays, and transitions are re-encoded.
But if you are deinterlacing for whatever reason, the entire thing will be re-encoded. Avisynth offers some better deinterlacers than TMPGEnc -
http://www.kiva.org/about -
Thanks trasporterfan (just tried this in Vegas, works nice), but I don't have a waveform in TMPG where I can detect the zero crossing points.
Well, I'm encoding the MPEG's to a HQ Divx file and eventually want to upload them to Youtube. I assume I will lose some quality. I've worked with Avisynth (restoration scripts), but I still like the results in TMPG better. -
Media info from the DVD-VOB/MPEG file:
Format : MPEG-PS
File size : 1 024 MiB
Duration : 19mn 22s
Overall bit rate : 7 389 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 19mn 22s
Bit rate mode : Variable
Bit rate : 7 050 Kbps
Maximum bit rate : 9 586 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.681
Stream size : 977 MiB (95%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 19mn 22s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -541ms
Stream size : 26.6 MiB (3%)
I want to edit said MPEG and re-encode to a HQ DIVX file. -
Strange that it shows as both progressive and top field first interlace. Is this camcorder video?
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan order : Top Field FirstRecommends: Kiva.org - Loans that change lives.
No, it's an NBA game from a recorded VHS tape. I bought the DVD's from a friend - and yeah that is weird. Most of them are Top Field / Interlaced.
I'm really not sure why I lose a considerable amount of quality in Vegas though. My project and media properties are set to that of the MPEG's. Absolutely identical. If I could just find out what is causing those loud pops/crackles in TMPG...
Best way to mask dropouts on old Betamax recordings?
By baakre in forum RestorationReplies: 27Last Post: 31st Mar 2013, 10:21 -
Repeated VHS Dropouts
By NitroPress in forum Capturing and VCRReplies: 2Last Post: 3rd Mar 2011, 09:03 -
Best way to Mask out Betamax video dropouts using hardware?
By Deter in forum RestorationReplies: 3Last Post: 10th Mar 2010, 11:02 -
Audio dropouts when capturing a particular Digital8 tape to DV
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 4th Aug 2009, 19:18 -
MKV Audio Dropouts
By hcour in forum AudioReplies: 2Last Post: 12th Nov 2008, 09:09
