I've got a DVD with a 5.1 ac3 file as the menu music. When it reaches the end of the track, a 'pop' can be heard from the speakers. This also happened to the main timeline of one disc, to the end of which I'd added a black image for one second.
Is this my speakers, or am I violating some sort of rule, or what?
Results 1 to 12 of 12
If you cut the sound track you probably neglected to find the 'zero crossing' points first.
http://forum.audacityteam.org/viewtopic.php?f=12&t=59558
Edit: forgot to mention the DC offset problem too, but it's in the link above. -
I think it's wrong. 128 is ridiculously low for a 5.1 mix. It would need to be 3 or 4 times that to get quality sound.
384 or 448 kbps would probably fix the sound distortion. As for Encore, can't help you there. Don't use it.
Also, did you trim your sound file equally in all channels? If one channel is longer than the other Encore may interpret it as corrupted. No offence, just making sure. Lol.
Edit: Use MediaInfo on the original file to see if it gives any better info.Last edited by transporterfan; 11th Apr 2012 at 16:36.
I didn't, because the zero points didn't match, but the 128 kbps one opens fine, so it's not that. MediaInfo has this to say about the original:
Format : MPEG Audio
File size : 567 KiB
Duration : 35s 928ms
Overall bit rate : 128 Kbps
Writing library : LAME3.98r
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 561 KiB (99%)
I exported at 384 kbps, and it works fine, though it is significantly louder for some reason. -
Unless the metadata is completely whacked, that's not 5.1 sound.
It's 2 channel MP3, and it actually is 128 kbps.
Are you sure that's the original and not your first 2 channel export attempt?
By original I meant the file on the DVD... -
Ah. I've got two copies of it: a stereo mp3 and a 5.1 ac3. And, like an idiot, I've been opening the mp3 file to see what bitrate it is. The actual 5.1 ac3 is, indeed, 384 kbps and significantly louder than the mp3.
This is why you don't troubleshoot at three in the morning.
Popping, clicks, dropouts when making cuts
By chef2 in forum EditingReplies: 7Last Post: 28th Apr 2012, 20:01 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Audio popping with long movie's
By md0234 in forum ffmpegX general discussionReplies: 0Last Post: 20th Oct 2007, 13:50 -
Help with popping & cracking sound from pc
By gyles in forum AudioReplies: 1Last Post: 12th Aug 2007, 14:54 -
How to figure out why during playback skipping, popping occurs
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 29th Jun 2007, 00:57
