Hi, guys,
Wonder if you could help me out here, I have a video file I want to edit on virtuadub but it has many corrupetd sectors.
My plan was to use anivideo converter to change it into avi format but it keeps freezing at 100%.
I literally need a steamroller, a robust converter who can go through those bits and bytes and crush them all into avi format whether theyīre good or bad/corrupted date.
I donīt care what it does with the corrupted sectors, whether it erases them or turns them into white noise, as long as I can open the avi file and go at them with virtua scissors.
"They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
When you play it forward, it installs windows." -
Hi, Transporterfan,
in the properties pannel it says .mvb, not a multimedia format Iīm very familiar with."They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
Is this a RealMedia file? What does MediaInfo say about it?
https://forum.videohelp.com/threads/175215-Handling-RealMedia-with-VirtualDubMod
https://www.videohelp.com/tools/Real7ime-Converter
