Hello
I use ffmpegX to convert .mov files into .flv files.
all seem's to be OK but...
when I launch a .flv file with QuickTime Player or with a Flash player (like JWPlayer )... the duration is still to "0:00"
The initial .mov files let me see the duration with QuickTime Player.
Is there a way to show duration ?
Is that normal or a bug ?
Thank you ++
If the file plays okay, but the duration is not shown, then your issue is likely with the missing meta data inside the flv.
In order to have ffmpegX insert meta data into the flv file, you should install flvtool2, as described on the website ("Optional install: if you want to encode flv with metadata") and in the videohelp.com announcement post.
Did they ever make a portable flash video player that plays .flv videos?
By snafubaby in forum Portable VideoReplies: 0Last Post: 25th Feb 2012, 00:21 -
Duration & Last Timestamp Conflict On .Flv File
By ThreatTV in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 07:04 -
QuickTime player giving black screen on AVC1 file
By Kaz Pinkerton in forum MacReplies: 1Last Post: 18th Jan 2009, 19:06 -
X264cfw encoded file does not play in Adobe Flash Player 10.
By RussellB in forum Video ConversionReplies: 1Last Post: 14th Nov 2008, 21:49
