http://ffmpegX.com/download.html
v0.0.9y - Jan 26, 2008
- Fixes for Leopard compatibility
- Added iPhone preset
- Added metadata in FLV encoding (to enable progress indicator in Flash video playback)
Note: to use the FLV metadata feature you also need to install FLVtool2 available here http://rubyforge.org/frs/download.php/17497/flvtool2-1.0.6.tgz
1/ decompress the folder
2/ open terminal.app
3/ cd [drop folder here]
4/ ruby setup.rb config
ruby setup.rb setup
sudo ruby setup.rb install [will require that you enter your login password]
Results 1 to 13 of 13
I tried that new version with few DV to H.264 conversion.
No bug so far
Great work major !
One thing I wanted to report for a long time now...
Would it be possible to save the "Open Terminal Window..." setting ?
I always use the terminal to encode and it would be nice to keep that setting between every launch.
In fact there seems to be an issue with the crop filter.
Or maybe it's the video I use...
Here are some screenshots and the settings used.
Crop was set to 2, 6, 6, 2 and didn't seems to really worked...
Original file informations
Original capture
Encoded capture
Settings
http://gerome.free.fr/forum/ffmpegX/crop.ffx
Any guesses
NopeOriginally Posted by major
I get this error:It would be nice to know what's wrong, since I've followed the instructions... Does it need a restart? Change of persmissions?Code:/Users/per_h/Applications-Test/ffmpegX.app//Contents/Resources/flvtool2: /usr/local/lib/ruby/site_ruby/1.8/: bad interpreter: Permission denied
a) "Permission denied" seems to indicate that you aren't logged in with an account that has administrator privileges.Originally Posted by grindstugan
b) ffmpegX should be in /Applications, the all-users Applications folder in the root of the boot volume. Another reason to log in as admin.
c) check if 'ruby' is in /usr/local/lib/ruby/site_ruby/1.8/ . Mine (PPC, 10.4.11) was in /usr/bin/, and I had to change that to make it work.
Do we still need to substitute the .9s mencoder in order to modify size and position of subtitles?
Well, probably... but noOriginally Posted by Case
a) I've logged in as an administrator (and installed the packages as one) - but if privileges are correct set it shouldn't be a problem.
b) I've tried with FFMPEG in /Applications with the same result, but that shouldn't cause a problem either (since the ruby app is called directly).
c) Ok, that could be it but...
When I change the script according to the instructions in your refreence I get:So that doesn't seems like the solution.Code:/Applications/ffmpegX.app//Contents/Resources/flvtool2:2:in `require': No such file to load -- flvtool2 (LoadError) from /Applications/ffmpegX.app//Contents/Resources/flvtool2:2
Im fully aware that there is some kind of misconf on my behalf, but I'm following the instructions and get no help.
Please give me some more ideas to test
ffmpegX 0.0.9y-L for Mac OSX 10.7 "Lion" released
By major in forum ffmpegX general discussionReplies: 10Last Post: 29th Jan 2012, 03:27 -
Avast 5 Released...
By Poppa_Meth in forum ComputerReplies: 11Last Post: 29th Jan 2010, 14:48 -
AV Linux 3.0 released.
By GMaq in forum LinuxReplies: 9Last Post: 14th Dec 2009, 08:38 -
MacDVDBitrateParanoia v0.5 now released!!!
By bendermac in forum MacReplies: 12Last Post: 29th Apr 2008, 15:10 -
Ubuntu 7.10 released
By Baldrick in forum ComputerReplies: 10Last Post: 26th Oct 2007, 10:41
