Hi, I have 4 vobs that I want to burn to DVD - I was following Baldrick's guide for this: https://forum.videohelp.com/threads/68128-How-to-author-burn-a-DVD-from-VOB-trailers-files but I fell at the first hurdle - VobEdit won't join the titles, I get to 'dialog okay' I expect to see a progress bar, but when I click OK and nothing happens. Any ideas?
Don't use that old method. Try reauthor with dvdauthorgui instead. Load all vobs and author and then burn the video_Ts folder with imgburn.
I just have VOB's so DVD AuthorGUI is throwing up this message 'Nav packets are not detected in VTS_.... Please demultiplex' I have PgcDemux, - that one should do it, but can't get it to work maybe settings are wrong? Maybe something is wrong with vobs...... also have Muxman and ImagoMPEG-Muxer and DVD Decrypter not sure if any of them will do the job....? Sorry, I'm not used to having to demux files
Batchdemux(extract all files to a folder and run batchdemux), choose directory with vob files, run demultiplex. Or tsmuxer, open vob, select demux.
If they fail it's probably not standard vob files.
demuxing VOBs with VobEdit
By siluet in forum Newbie / General discussionsReplies: 13Last Post: 22nd Nov 2012, 16:57 -
Are you able to join PAL and NTSC vobs together?
By ramrod1234 in forum Authoring (DVD)Replies: 12Last Post: 26th Apr 2008, 04:27 -
VOBEDIT - BUG - joins vobs into 80kb chunks
By ramrod1234 in forum EditingReplies: 0Last Post: 25th Apr 2008, 04:29 -
TDA won't display video thumbnails after Vobedit
By spiritgumm in forum Authoring (DVD)Replies: 4Last Post: 25th Aug 2007, 14:35 -
How to join 3 VOBs in VirtualDubMod
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2007, 11:09
