I started a new thread instead of piggybacking on an old one, hope no one minds.
I have two mkv 720 HD movies (blu-ray rips ), the Godfather 1 & 2 . Neither one has the forced subtitles in them, (the parts where they talk Italian). Two questions. 1) Is there a site where I can download just the forced subtitles for these movies. 2) If the answer to #1 is yes, what software can I use to put these forced subtitles back into the movie? (is it called remuxing?). This gets confusing. Thanks for any assistance!
1. Search https://forum.videohelp.com/threads/305253-Good-subtitle-sites
2. mkvtoolnix can multiplex subs to the mkv. If you want hardcoded subs in the video you can use freemake video converter or avidemux and reconvert. -
A lot of blu-ray titles do not have subtitles marked as forced. So am afraid your search to find such may be futile. I've not seen a subtitle site that has the non enlish pats of the movie.
As an after thought the best way to rip a movie, is to de-mux all subtitle streams if you have multiple English streams.
Now that you have all the Enlish subtitles you need to identify the one you want. Sometimes the subtite will actually be labled like "english_forced" (in ripbot they often are) if so the wok is done for you. If none of the subtitles are labeled forced you have a few of options available to identify the correct subtitle stream..
1.Identify which subtitles are set default using bdedit.
2. An easier method would be to convert the English subs to .srt load the txt files into your text editor and identify the correct subtitle file.
3. Convert subs to English mux each of them into your mkv\mp4. Play the file and select sub streams to determine correct one. Re-mux using mkvMerge marking that stream as default, you can then un-check the other sub streams to exclude them from the muxed mkv.
In your case i would de-mux my disk again, and use one of these methods to mux the subtitle stream into my mkv.Murphy's law taught me everything I know. -
http://www.opensubtitles.org/en/subtitles/3590602/the-godfather-en
The.Godfather.1972.BluRay.1080p.DTS.x264.dxva-EuReKA.ENG_Forced.srt
http://www.opensubtitles.org/en/subtitles/3590605/the-godfather-part-ii-en
The.Godfather.II.1974.BluRay.1080p.DTS.x264.dxva-EuReKA.ENG_Forced.srt
Since they were evidently sourced from the BluRay, maybe you can do it yourself.
In any case, as always, check and adjust the sync.
forced subtitles question ...
By zero7404 in forum Blu-ray RippingReplies: 0Last Post: 17th Aug 2011, 22:31 -
Forced Subtitles
By sxj1704 in forum Blu-ray RippingReplies: 4Last Post: 29th Jan 2011, 09:17 -
MKV TO BD-R with forced subtitles
By wthldh in forum Video ConversionReplies: 6Last Post: 21st May 2010, 11:19 -
Forced Subtitles Only In First Stream
By sambat in forum SubtitleReplies: 3Last Post: 28th Apr 2009, 23:05 -
The Mummy - How to get the forced subtitles
By Mascot in forum Blu-ray RippingReplies: 19Last Post: 20th Apr 2009, 21:01
