I am burning low-quality avi files to DVD to play back on a standalone player. One of the things I've noticed in some of the videos is that the movement is jittery, especially during fast-motion scenes. It's almost like watching a flipbook movie. I am wondering if this has to do with re-setting the bitrate to a maximum level (4000) when encoding the file. I've noticed that the kbps number changes when a new file is imported into ffmpegX and I'm wondering if it is better to leave it rather than resetting to max kbps by reselecting the "DVD ffmpeg" option. I am going to try re-encoding one of the jittery movies and leaving the bit rate as it to see if there is a difference, but if there is anyone with more info on this please let me know what I'm doing wrong. Thanks in advance.
Why are you setting the bitrate to maximum (4000)? Yes, high bitrates often do cause problems for standalone DVD players capable of playing video files.
Did the original videos from which you converted have extremely high bitrates? If not, you're not really gaining anything by setting the bitrate too high, other than larger file sizes and videos which standalone players might have problems playing. You might keep this post in mind when creating AVIs for your player: Common DivX DVD Players AVI Playback problems!If cameras add ten pounds, why would people want to eat them?
http://www.kiva.org/about
Actually encoding the file to DVD with the bitrate set higher did improve the quality of the video. I've burned both versions to DVD and the files with the bitrate left at the lower default setting looked much worse. However, the higher setting did nothing to improve the jittery movement of the images, probably because of the way the original file was saved or encoded.
Since the 'source' is AVI and most likely progressive, I wouldn't think a field order reversal could be the problem. But stranger things have happened and a sample could prove useful.
cb678, If you provide a sample of the output, 10 seconds or so with steady movement, I think we can diagnose the problem. I'm assuming the AVI from which you made the DVD doesn't display this jittery movement. Is that correct?
A ffmpegX's problem about setting the audio bitrate
By lzero1319 in forum ffmpegX general discussionReplies: 1Last Post: 7th Apr 2012, 08:44 -
MKV to AVI Video Bitrate Setting
By gonwk in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2011, 19:31 -
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 07:12 -
Software that will allow to see what bitrate a movie or iso file is encoded
By Teac23 in forum DVD RippingReplies: 6Last Post: 21st Apr 2010, 19:22 -
burning avi file is jittery
By fredted40x in forum Video ConversionReplies: 1Last Post: 4th Jul 2007, 11:48
