Results 1 to 10 of 10
    Jul 2007
    Hi guys,
    I've got a video saved from the web which is 720p, I'm a little confused though as MediaInfo doesn't give me a framerate:
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : 27
    Duration : 2h 36mn
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Audio
    Menu ID : 1 (0x1)
    Format : AAC
    Format version : Version 4
    Format profile : SSR
    Muxing mode : ADTS
    Codec ID : 15
    Duration : 2h 36mn
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Delay relative to video : -22ms
    And when I load it into DGAVCIndex to create a project file for encoding it says 25fps. Shouldn't it be 50fps? Or does that mean it's actually 25fp and each frame is just doubled?
    Is there a way I can check exactly what this is, and then get the best method for converting it to DVD? I know it's PAL video so 576i would be my target but how would I handle the interlacing? I would be encoding via an AVISynth script.
    Thanks in advance.
  2. Originally Posted by Killer3737 View Post
    Why would it or should it be 50fps? FPS means frames per second. If you mean 50 fields per second, then say it.
    Is it interlaced? You've seen the interlacing? You know 720p means progressive, don't you? If it's not interlaced, just resize it and encode.
    Jul 2007
    I think I am getting a bit confused here to be honest, I know it's progressive which I thought meant 50fps? I was looking at this thread for reference - https://forum.videohelp.com/threads/273233-HDTV-720p-50-fps-SDTV-PAL-576i-p-25fps
    I don't see any interlacing at all, no.
  4. You downloaded it, right? So who knows what's been done to it already. The other link to which you referred had a real 50fps capture for a source, not a reencoded video. Progressive just means progressive and has nothing to do with the framerate. As for confirming the framerate, since you'll be using an AviSynth script, open the script in VDub or whatever and check the framerate and see what it says. I'd be inclined to trust what DGAVCIndex says about it. When advancing a frame at a time, is every other frame a duplicate? No, eh? And this is film sourced isn't it, a movie maybe?
    Jul 2007
    It's a live music video stream downloaded from iTunes so the only people that have done anything to it are iTunes. Not film sourced, HD video cameras. I was stood next to them in the venue when it was shot.
    So I created a script with just a resize and colorimetry change and VirtualDub does say 720x576 25.000fps when I load the avs into it.
    So that is correct and will output a DVD compliant stream?
  6. I don't think I've ever heard of a two and a half hour music video. That's why I thought it must be a movie.
    Yes, there's no reason you shouldn't get a DVD compliant video out of it. Technically, you'd resize to 704x576 and then, if you wish, add borders to fill it out to 720. It's a minor point, though:
    LanczosResize(704,576)#or your favorite resizer
    Addborders(8,0,8,0)
    Jul 2007
    Well it's a live show to get technical.
    What is the reason for those borders, TV overscan?
  8. No, closer to the correct aspect ratio (assuming the source was done properly). But, as I said, it's a minor point as there's only about a 2% difference between the two.
    Jul 2007
    Ok, thanks for the information.
  10. I disagree with the resizing. The DVD spec refers to the MPEG 2 spec for aspect ratios. The MPEG 2 spec is very clear: the full frame constitutes the indicated display aspect ratio (unless overridden by a Sequence Display Extension -- which I've never seen used for that purpose). That is at odds with the BT/rec digital video spec where the central 704x576 (or 704x480) subsection constitutes the indicated DAR -- which is where the confusion comes in. I've seen DVDs done to both specs (by measuring what appears on-screen during playback). In any case, the ~2 percent difference isn't worth worrying about.
