Hi Guys,
I'm wondering if there is an app capable of re-naming *existing* chapters in Mp4/Mkv, etc ?
Currently with MediaInfo, I can see there is a list of chapters like this +/-:
01 - Chapter 01
02 - Chapter 02
03 - Chapter 03
Is there a way to rename them?
Thanks for any helpful info!
Popcorn chapter maker can do that.
Load that mkv into Chapter Maker , rename those chapters, save XML . Run MkvMerge Gui, uncheck those chapters and load that new XML under Global TAB, Chapter Files. There might be easier way to do this, but I go through this XML file. As a matter of a fact Popcorn Chapter maker is a tool for me to create that XML file, that I use in MKV Merge gui for my home videos. -
Thanks for the feedback, do you have a link for that "Popcorn chapter maker" as I can't find anything via google. Thanks
PS: I'm on a PC.Last edited by TYLER08027; 13th Jul 2011 at 19:54.
download zip http://www.unival.realservers.info/uploads/ChapterMaker.zip
here is a discussion from popcorn forum: http://188.138.72.109/showthread.php?tid=13034&page=3
Antivirus might report some virus, but author says in that thread that it is ok
I was into this some time ago, I use mkv for home videos with extra audio tracks, subtitles (datestam or comments), did research how to create chapters with gui interface and possibly with visual feedback. This is only what I found to my supprice . -
I have an update, it just came up today, based on this thread:
https://forum.videohelp.com/threads/336919-Tool-for-Editing-MKV-Without-Re-Writing-Entire-File
It is very easy to change or create chapters for MKV file, without muxing the MKV again using mkvproedit.exe !
Create newchapters.XML perhaps with that Popcorn Chapter maker, that loads mkv only file anyway, and then run this command in command window:
mkvpropedit --chapters newchapters.XML "C:\......\movie.mkv"
So there is no need to remux mkv again just for adding chapters
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 20:50 -
Mkv xml chapters to mp4
By Sem in forum Newbie / General discussionsReplies: 0Last Post: 2nd Apr 2011, 18:31 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 03:10
